What Engine mounts?
Old Mar 31, 2009 | 11:53 PM
Luckywhiteboi's Avatar
Default What Engine mounts?
Im clueless.
What are good engine mounts to use? Im not boosting and i dont expect to go that high in horse power, but i would like stiffer mounts then stock. (GSR)
Old Apr 1, 2009 | 12:27 AM
V8 Eater's Avatar
Default Re: What Engine mounts?
you dont want to spend a **** load of money like you would with hasport,nor do you want to cheap out and buy some ebay ****(you get what you pay for). I would go with avid, they are right in the middle with a fair price, and they have many versions of mounts for you to choose from(go with the softest IMO). The difference between stock is very noticable yet not too stiff to the point where you want to jump out of the car like you would with hasport!
Old Apr 1, 2009 | 12:39 AM
HYREV2NR's Avatar
I've had Prothane inserts for some time now. They are a bit stiff but it's not that bad to me. Most of my vibrations are at idle. I had ES inserts but they weren't stiff enough for me. Both are a cheap fix.
Old Apr 1, 2009 | 04:42 AM
96b18c-r's Avatar
prothane inserts f****** suck! i had those and one popped out, my motor mount tour, and then my valve cover rubbed on my hood and looks like complete ***. OP go with a proper mount, my opinion on the inserts is that really are the worst way to go other than have stock mounts that is... i'm in the process of getting some almost new hasports from my buddy for $250. see if you can find a good such as i just did on a better set of mounts. heard hasports are ruff but they're reliable.
Old Apr 1, 2009 | 08:39 AM
HYREV2NR's Avatar
Thats the first I've ever heard of inserts of any brand coming out of place. I had mine for a long time with a JRSC on the car, endless passes down the 1320 and never missed a beat. Sorry for your bad experience.
Old Apr 1, 2009 | 11:00 AM
NATEDEEZY's Avatar
Innovative steel mounts
Old Apr 1, 2009 | 12:33 PM
BMo Tuning's Avatar
STAR
weld them solid
Old Apr 1, 2009 | 08:06 PM
CivSiClone_96's Avatar
Go with Innovative solid mounts there just a little under 300 and there good mounts for what you pay for.
Old Apr 2, 2009 | 05:43 AM
Dark_Teg's Avatar
I have the street version of the Hasport mounts and they send some vibration through the car but not too bad. I think solid mounts would drive you insane.
Old Apr 2, 2009 | 07:47 AM
cockerkid008's Avatar
Innovative Steel mounts in 60A or 75A
I run the 75A in my car and love them. There isnt too much vibration but I know the motor is going to be moving a lot less than stock mounts
Old Apr 2, 2009 | 07:52 AM
bokals's Avatar
Honestly, Solid motor mounts are really are not meant for daily driving. If you dont use washers on your subframe you can weaken the subframe. I had them for a month, They are nice, No motor movement, but its like having a second exhaust.
If you got the extra money buy Hasports, or get used Hasports. Innovative makes really good mounts.
Avid are ok, I've owned these too as well.
Innovative is the way to go if your budget minded person. You wont feel much with regular Hasport mounts only at idle you will.
Hope this helps.
Old Apr 2, 2009 | 07:57 AM
HYREV2NR's Avatar
One thing that hated about the stock mounts is all the wheel hop you get at the drag strip. When I first installed my inserts years ago, I cranked the car and said MY GOD WHAT HAVE I DONE???!!!
I noticed the vibration is not as bad once the car warms up and now I can't imagine not having them. I like the feel and sudden response to the throttle they give.
My next venture will be some actual solid brand name mounts like Inovative or Hasport.
Old Apr 28, 2009 | 11:25 PM
NATEDEEZY's Avatar
get an innovative traction bar that will take care of your wheel hop
Old Apr 29, 2009 | 05:41 AM
FST GSR 1's Avatar
The stiffer the mounts, the harder it is on the drivetrain.
Old Apr 29, 2009 | 08:36 AM
98vtec's Avatar
moderator emeritus
what does this have to do with all motor?
clem kevin
May 1, 2008 06:57 PM
Turbo-charged
Mar 11, 2008 04:24 PM
svacca1
Nov 27, 2006 09:27 PM
vtecmike1
Nov 19, 2003 07:19 AM
mattL
Mar 29, 2003 01:57 PM
