Vtec doesnt stay on.
Old Mar 26, 2009 | 10:48 PM
the_dxB16's Avatar
Default Vtec doesnt stay on.
I have a b16a and the vtec comes on for like the first 10 minutes from when i turn it on (its also when the car is warmed up). or when i do one pull in two or three gears. After that it turns off and the engine light comes on. All the conncetions are connected. the car is tuned to something i dont know but the dizzy is advanced. if the dizzy is at the regular positoin it has no power. When i turn the dizzy a bit back the vtec works. idk its all confussing but im in need. I raced a regular cobalt and lost and my vtec wasnt working. but any help would be appreciated. I can describe it more also sry.
Old Mar 26, 2009 | 10:51 PM
the_dxB16's Avatar
Default Re: Vtec doesnt stay on.
also when i get codes i get 8 short blinks thats the one that i get most of the time. another one i seen was 21. i took off the vtec solenoid the other day and put it back on.
Old Mar 26, 2009 | 11:06 PM
trustdestruction's Avatar
Not sure if it would work at all if this happened... but did you make sure that you didn't reverse the oil pressure switch and VTEC solenoid plugs when you put it back on?
Also, you need to adjust your ignition timing properly with a timing light.
Old Mar 26, 2009 | 11:09 PM
93egSLEEPER's Avatar
how much oil do you have? if it drops in pressure cause of lack of oil vtec will shut off.
Old Mar 26, 2009 | 11:35 PM
the_dxB16's Avatar
the switches are correct, how can i check the pressure of the oil and fix it? i had one valve cover bolt broken and i had just the seal covering it and was driving for about two days but just to the store and back type of driving. i replaced that bolt yesterday. could that put air in the engine? is there any way can clean the vtec solenoid? also i dont have a timing light but can auto zone rent one out?
Old Mar 26, 2009 | 11:38 PM
Just check your oil level and make sure it's proper.
Broken valve cover bolt isn't a huge deal, just try to get it fixed. It wouldn't cause problems like this though.
Old Mar 26, 2009 | 11:41 PM
the_dxB16's Avatar
my oil level is good. can a bad oil filter do this?
Old Mar 26, 2009 | 11:42 PM
sportin_ej1's Avatar
Check your oil levels man my friend rocket has the same problem with his b16 he burns oil to quick
Old Mar 26, 2009 | 11:43 PM
maybe if it was extremely clogged... but i bet you'd have bigger problems if that were the case
Old Mar 26, 2009 | 11:48 PM
numberone's Avatar
[QUOTE=trustdestruction;37931733]Not sure if it would work at all if this happened... but did you make sure that you didn't reverse the oil pressure switch and VTEC solenoid plugs when you put it back on?
Wtf? The plugs will not go on each other.
Old Mar 26, 2009 | 11:50 PM
I've heard of people putting the plugs on backwards before. I'm not sure how, but i've heard about it.
Old Mar 26, 2009 | 11:54 PM
the_dxB16's Avatar
can hoses affect the vtec even if they are cracked at the very end? such as intake manifold to gas thing...
Old Mar 26, 2009 | 11:55 PM
the_dxB16's Avatar
idk il try again tomorow and check everything i can.
swizz977
10
May 25, 2011 08:15 PM
MyIntegra
Jun 12, 2009 10:54 AM
FormulaIntegra
24
Mar 26, 2009 08:35 AM
DsBananas94LS
Dec 5, 2004 07:51 PM
THE SOUND OF VTEC
Apr 30, 2002 12:20 AM
