99-00 si radio/cd player into my 97 ex...keyless entry?
Old Mar 25, 2009 | 08:08 PM
ggDOHC's Avatar
Default 99-00 si radio/cd player into my 97 ex...keyless entry?
so i want to install my 00 si headunit into my 97 ex coupe. the connectors are different and my keyless entry runs through my stock headunit. any way around this in order to keep my keyless entry and the si radio?
Old Mar 25, 2009 | 08:13 PM
98civdx's Avatar
Master Detailer
Default Re: 99-00 si radio/cd player into my 97 ex...keyless entry?
you may have to look into an aftermarket alarm with keyless...
try hooking eveything up and see if it still works.
get the si harness and then the 97 harness that plugs into your car... match everything up
the keyless doesnt go through the si deck? i always thought it did.
but there is a stereo section that youll prolly get more help from....
Old Mar 25, 2009 | 08:19 PM
ggDOHC's Avatar
thanks!
Old Mar 25, 2009 | 08:59 PM
92'si's Avatar
there is a harness from crutchfield that will power both units so you can retain keyless. You will just need the harness for the 99 and wire it into the aftermarket harness.
http://www.crutchfield.com/p_1207017...search=harness
Old Mar 25, 2009 | 09:00 PM
92'si's Avatar
on the 99-00 the brain for the keyless/security is seperate from the head unit.
Old May 8, 2009 | 01:37 PM
WickedGarden's Avatar
See this thread if you still have any Q's:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/97-ex-coupe-keyless-entry-aftermarket-radio-2528527/
(applies to 96-98 Civic)
97_Ek
Mar 24, 2008 05:59 PM
UnrealSpeed
11
Jul 21, 2003 11:46 PM
fowler!
Jun 8, 2003 11:16 AM
Cynical 1
10
Jan 4, 2003 06:16 PM
Bleed Black
Mar 26, 2002 03:56 PM
