My new B16 turbo leaking oil...
Somebody help me!!! My engine its leaking oil between engine and tranny while its on. I change the seal for a new one but continue the problem. What can i do?
change it again. i also had a leak from my rear main seal after replacing it the first time. i ended up buying a new cover with seal and installing it. seems to be okay now. don't forget to lube the seal so it doesnt get torn by the crank the first time you start the car.
Thanks for replys!!! Its wierd that is the third time that i change the seal(OEM)l in a long time and the first that i have this problem. I was thinking in a bore problem?
LSVTEC 91 Civic
Apr 26, 2005 04:23 AM
EJ1 wilcox
Feb 14, 2005 10:30 PM
