My new B16 turbo leaking oil...
Old 03-24-2009, 07:10 PM
k_civic's Avatar
Default My new B16 turbo leaking oil...
Somebody help me!!! My engine its leaking oil between engine and tranny while its on. I change the seal for a new one but continue the problem. What can i do?
Old 03-24-2009, 07:23 PM
wpgredteg's Avatar
Default Re: My new B16 turbo leaking oil...
change it again. i also had a leak from my rear main seal after replacing it the first time. i ended up buying a new cover with seal and installing it. seems to be okay now. don't forget to lube the seal so it doesnt get torn by the crank the first time you start the car.
Old 03-24-2009, 07:36 PM
90blackcrx's Avatar
Did you install it properly ? They are suppose to have a gap behind the lip on some applications.
Old 03-24-2009, 08:00 PM
k_civic's Avatar
Thanks for replys!!! Its wierd that is the third time that i change the seal(OEM)l in a long time and the first that i have this problem. I was thinking in a bore problem?
jald3rd
06-30-2017 08:49 AM
kihun_cha
02-18-2007 12:10 PM
LSVTEC 91 Civic
04-26-2005 04:23 AM
EJ1 wilcox
02-14-2005 10:30 PM
raene
06-18-2002 09:06 AM
Quick Reply: My new B16 turbo leaking oil...
