Farther Nitrous purge???
I wasn't sure exactly where to put this topic since it really isn't performance related. Basically just want to settle this argument.
My cousin and I had a disagreement last night while working on his drag truck.
When it comes to his truck, he's kind of a showboat.
Anyway, he has the nitrous purge coming out of the hood and wanted it to go higher in the air. I told him that if he wanted it to go higher, he should use a smaller diameter line from the purge to get a more narrow "stream" that would be forced higher. He disagreed and said that a larger diameter would flow more. I thought this would just make a larger/wider cloud. I tried using the garden hose nozzle analogy where the smaller hole setting shoots farther.
After multiple "You're a fu**ing retard", "I'm right" & "I really just want to punch you in the face right now" comments were exchanged we never came to a conclusion.
What does H-T think?
That's what I thought. Thanks guys.
He used to be into the lowrider scene back in the day so everything he did was all show. He's coming around tho.
