Nitrous without a Purge
Old Jun 11, 2004 | 03:40 AM
variablevalve's Avatar
Default Nitrous without a Purge
Okay, searched. I was just wondering what are the dangers of running nitrous without a purge kit?
Old Jun 11, 2004 | 04:53 AM
PM-Performance's Avatar
Default Re: Nitrous without a Purge (variablevalve)
not making all the power you can becuase of air pockets in the lines or "Stale" nitrous left over in the lines
Old Jun 11, 2004 | 06:17 AM
black98gsr-t's Avatar
I honestly don't think your going to feel the difference. you might set it at the track 1-2 tenths. I ran my nx kit for a year with no purge it pulled all the same. nitrous pressue is around 800-1200 psi. any air will quickly be purged when you hit the spray.
Old Jun 11, 2004 | 06:19 AM
Default Re: Nitrous without a Purge (black98gsr-t)
you should feel quite a diff, i know i did. but even so , 1-2 10ths is alot for just clearing out your lines.
Old Jun 11, 2004 | 07:07 AM
hoggy's Avatar
Think about it like this. You have a small line running from front to back with 14.7 psi (atmospheric preassure) of air in it. You apply 1000psi of nitrous to that line. The air is gonna be a pretty small portion of the line.
If this is for drag only then thats more where it comes in play for street. I would rather use the amount of nitrous that gets purged through the motor. Its a lot more fun than spraying your money away.
Old Jun 11, 2004 | 07:33 AM
Default Re: (hoggy)
its a totally diff story when you run nitrous and you know from experience. im telling you from experience its a good buy. whether you get it or not ,thats up to you, but its deff worth it . if you need that quick kick in the *** and dont get it becuase there is an air pocket in there. then guess what? it could mean the diff between winning and losing .
Old Jun 11, 2004 | 08:55 AM
RyanEJ8's Avatar
Default Re: (itr206)
Purge with a burnout. The only reason I bought a purge kit was to easily clear the lines after use.
JDCB16Cx
Mar 20, 2009 01:44 PM
civicx98
Honda Civic (2006 - 2015)
Jun 30, 2007 07:44 PM
DarkDragon
Jul 26, 2005 07:38 PM
onewisepunk
Feb 2, 2004 09:58 PM
allshownogo7
Feb 13, 2002 07:34 PM
