right headlight only works when brights are on
Old Mar 16, 2009 | 07:46 PM
tealchief's Avatar
Default right headlight only works when brights are on
one works fine but the other only works when i have the brights on, does any one else think this is the relay. or something else
thanks!
Old Mar 16, 2009 | 07:48 PM
Blzdeep's Avatar
Default Re: right headlight only works when brights are on
Could just be the bubls low filament no ? Did you check the wires to make sure one isnt loose and shorting out ?
tdbhonda's Avatar
have you tried replacing the bulb
Old Mar 19, 2009 | 11:26 PM
thereverendstu's Avatar
I have the same problem and I just put a new bulb in.
Old Mar 19, 2009 | 11:28 PM
Leady's Avatar
That's what happens when one filament of your dual filament bulbs burns out. Replace the bulb.
Old Mar 20, 2009 | 12:01 AM
D16SiHatch's Avatar
haha yep ^
Old Mar 20, 2009 | 07:08 AM
The bulb is brand new but the problem still persists.
Old Mar 20, 2009 | 08:16 AM
jrod95cpe's Avatar
check your fuse mate, mighta just blown one i did the other day and my left light did the same thing
Old Mar 20, 2009 | 08:26 AM
Weak!EG's Avatar
when you say the bulb is brand new, do you mean you've replaced it since this problem started? if not change it again.
Old Mar 20, 2009 | 08:31 AM
teamworxek9's Avatar
try switching the bulbs from the other side if it does the same thing check the fuses. did you loosen the ground on that side for any reason?
Old Mar 20, 2009 | 09:58 AM
Yeah, brand new bulb from the parts store. It's been tested and it functions properly.
There's a fuse for low beam AND high beam? Where's the fuse? Under the dash or the hood?
Old Mar 20, 2009 | 10:48 AM
should be with all the other fuses.
Old Mar 20, 2009 | 03:22 PM
You do know there are fuses under the hood as well along with various relays too, right? Anyway, it turned out to be a 10 amp fuse in the under DASH fuse block. I never knew there was a fuse for the high AND low beams. Learn something new every day lol.
Old Mar 20, 2009 | 04:16 PM
DOUBLExDEUCEx22's Avatar
thats weird. i never heard of that but recently my friend had the same problem.
Sol2Take
Lighting
10
Mar 20, 2012 06:10 PM
jtthwaits
Mar 5, 2011 05:40 PM
Bambooseven
Mar 3, 2009 08:40 PM
Krayzielix
Oct 23, 2005 06:07 PM
GSblueRacing
May 28, 2004 06:27 PM
