hid problem??
Old Oct 22, 2005 | 04:33 PM
Krayzielix's Avatar
Default hid problem??
the problem is like 10min after it warms up...my passenger side light dims down a lil is this normal..its a mccullugh kit..i had for about 4months with no problems till now...anyone kno what could be wrong?
Old Oct 22, 2005 | 05:10 PM
Krayzielix's Avatar
Default Re: hid problem?? (k12ayz1e)
anyone
Old Oct 22, 2005 | 05:26 PM
Krayzielix's Avatar
if i turn it off then back on its fine then it does the samething again..it doesnt really dim just color is a lil off
Old Oct 22, 2005 | 06:12 PM
1turbodc2's Avatar
yes its normal it takes them a little bit to adjust. and the color does change from when they first ignite.. i don't about 10mins though
Old Oct 23, 2005 | 10:09 AM
Krayzielix's Avatar
Default Re: (gssr)
yea but it never did this before..an it flickers when u turn it on now
Old Oct 23, 2005 | 12:56 PM
LowTEC SaiMike's Avatar
Default Re: (k12ayz1e)
Was a Brand new kit when u bought it ? could be ground going bad or something
Old Oct 23, 2005 | 03:37 PM
Krayzielix's Avatar
Default Re: (BomBoi)
yea it was brand new
Old Oct 23, 2005 | 04:48 PM
ninhers's Avatar
try to swap the bulbs or ballast from one side to the other and see if the problem switches sides. this would be the best way to see what is causing the problem. if both bulbs work fine on one ballast but not the other, it means that you have a bad ballast. same goes for the bulbs. hope this helps
Old Oct 23, 2005 | 04:51 PM
mikey_008's Avatar
Umm.....it's either the ballast...or try changing your fuse to something higher!
Old Oct 23, 2005 | 06:07 PM
Krayzielix's Avatar
Default Re: hid problem?? (mikey_008)
aite ill do that thanx
#Hatch
Lighting
May 3, 2012 07:42 PM
ef0cmacro
Lighting
Feb 1, 2010 07:07 PM
EJ6_Sedan
19
Nov 21, 2007 10:21 PM
TypeRod
Mar 5, 2004 03:16 PM
TurboDC4
Apr 1, 2003 06:20 AM
