so what do you guys think of this E-ram contraption??
Old Aug 12, 2002 | 03:07 PM
TONEBONE's Avatar
Default so what do you guys think of this E-ram contraption??
http://www.electricsupercharger.com anybody ever seen one used on a car? If it really worked it wouldn't be that bad of a deal 1 psi of boost is better than none.
Old Aug 12, 2002 | 03:21 PM
isotopesope's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (TONEBONE)
looks like a scam.
Old Aug 13, 2002 | 06:15 AM
PSU-TEG's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (isotopesope)
Why would it be a scam?
The concept is not all that far fetched.
All the fan has to do is blow air faster than the intake stroke can pull it in, and there you have it.... in stead of vacum, you have boost. And they aren't claiming all that much from it power from it.
Don't know if it would work. It all depends on the fan (ok, the fan's motor...). I'll admit that I wouldn't by it until I see some data, facts, and figures proving its performance, but the concept isn't all that far fetched.
[Modified by PSU-TEG, 3:16 PM 8/13/2002]
Old Aug 13, 2002 | 11:31 AM
StyleTEG's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (PSU-TEG)
its crap
it puts a load on the alternator which in turns puts a load on the engine. It also creates turblent air which is bad for performance, so any gains that it might give by producing 1psi of boost would be squechled by the poor airflow quality.
Old Aug 13, 2002 | 12:34 PM
SC94DB8's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (StyleTEG)
I give the E-Ram 2 of these--> . In other words, I wouldn't buy it
Old Aug 13, 2002 | 12:52 PM
Kamin's Avatar
but at 6000rpm its not gonna let enough air into the engine
scam
Old Aug 13, 2002 | 12:58 PM
EE_Chris's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (KAMiN)
Put a nozzle on it to blow up balloon's...it'd probably be more effective.
Old Aug 16, 2002 | 11:45 AM
93CivicSI's Avatar
For 299.00!!!! - Rip Off!!!
Old Aug 16, 2002 | 12:01 PM
Todd Reid's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (93CivicSI)
it takes a ton of horsepower to drive a supercharger; like 20+ hp at high rpms. that is called "parasitic loss".
for this thing to be effective, it must pressurize high volumes of air into the intake tract....
have you ever seen a 20 hp electric motor? we use them here at work all the time to power large water pumps. a 20 hp motor is huge, and heavy.
i doubt that the e-ram has a very powerful electric motor (or it would be very difficult to fit into the engine bay) and i doubt it will do much.
sounds like another "tornado" to me.
good luck
Todd
Old Aug 16, 2002 | 01:17 PM
Mojo-Jojo's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (Todd Reid)
Tell ya what...I'll take a **** in your intake, and you can give me 150 bucks.
It'll do the same amount of good for your car, and it'll cost you $150 less than that piece of crap.
Old Aug 16, 2002 | 01:24 PM
ViZ's Avatar
ViZ
Default Re: so what do you guys think of this E-ram contraption?? (Mojo-Jojo)
i would save the money for something else...
Old Aug 16, 2002 | 01:38 PM
Chiovnidca's Avatar
LMAO It looks like the bilge fan in a boat. I can't see it doing much performance wise.
Old Aug 16, 2002 | 02:01 PM
raene's Avatar
This has been discussed before, way back when... final word was, it's a fan, not a compressor. Superchargers typically compress the air by moving it from one place to another, as in a Roots blower, but this doesn't have any capabilities for compression.
Old Aug 17, 2002 | 07:21 PM
Quick 200k Mile Motor's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (raene)
It will become a restriction
at high engine speeds.
its poopoo
Old Aug 18, 2002 | 07:45 AM
non-VTEC's Avatar
i would seriously like to see someone buy that thing and do dyno tests with it.........just to prove that it does or doesnt work........
Old Aug 18, 2002 | 08:54 AM
kb58's Avatar
Banned
Do the math. If you have a 2.0l engine, it consumes about 2.0l per cycle, * rpm / 2. So at 6000rpm, you need at least 2.0l * 3000 = 6000l per minute. And that's for exactly zero boost. Does it do that? Now double it to get any sort of boost. Does it do that?
There you go.
Old Aug 18, 2002 | 02:21 PM
bluedelsol's Avatar
if you do decide to get one dont get that e-ram POS get one of the ones off ebay, and not the cheap *** white ones, there are some that are selling for like 50-100 buks that look just like mini turbos ( the gray ones). i got one just to see if it would realy help and it improved my average track E.T. by about .5, dont know the exact hp gain, never did a dyno test, and if you get one make shure you get a good high flow filter, like one that is designed for a real turbo.
Old Aug 18, 2002 | 02:39 PM
mugenracer's Avatar
Default Re: so what do you guys think of this E-ram contraption?? (bluedelsol)
get your car dyno'd with it off and then with it on and post the results that should end the speculation over wether or not this thing actually works. If there were gains across the power band then i would consider buying one
GoodUsername
Aug 25, 2015 12:53 PM
skata89
May 9, 2007 07:13 AM
btrim23
Apr 18, 2005 08:34 PM
Jonathan_ED3
33
Jun 23, 2003 05:23 AM
