oil filter question
Old Aug 18, 2002 | 12:30 PM
EKB18BPR3's Avatar
Default oil filter question
as we speak im doing an oil change. my ? is...could i change the filter when the oil ISNT empty? cuz i bought the filter and everything and i also have the tool to screw the filter in/out...but this tool doesnt fit the honda filter.
Old Aug 18, 2002 | 12:51 PM
Mr. Choi's Avatar
New User
Default Re: oil filter question (dniedacess)
what are you talking about? do you want to change the filter then drive around with old oil? or did you change the oil and not the filter? you can change the filter with oil still in the engine, oil wont leak out from where the oil filter sits. if thats what you are asking.
Old Aug 18, 2002 | 01:45 PM
EKB18BPR3's Avatar
Default Re: oil filter question (Chois i-VTEC)
what happened was i took my car to get full tune-up at honda dealer the last time i got my oil changed. well like always 2000 miles later it was due for another one. i got the new oil and a new filter. i have this tool that fits rite over the filter and uses a rachet to unscrew/screw the filter. well my special tool doesnt fit the honda filter so i had no choice but to change the oil but not the filter. so i have to buy another special tool to change the freaking honda filter. so will any oil spill out from the filter hole while the oil is still in there?
Old Aug 18, 2002 | 02:03 PM
ShootingStar's Avatar
Unless you're using some liquid gold at $5+ a quart, suck it up and change em both, AGAIN. It's ONLY your car!
[Modified by ShootingStar, 11:13 PM 8/18/2002]
Old Aug 18, 2002 | 02:25 PM
94gsr's Avatar
There will be oil in the old filter when you pull it off, but that will be the extent of the leakage. The oil in the engine drains down to the oil pan when the car is not running.
And the special tool that you're referring to is called a filter wrench.
Old Aug 18, 2002 | 02:33 PM
mugenracer's Avatar
Default Re: oil filter question (94gsr)
if your working from underneath the car you shouldnt need your 'special tool' the filter should only put on hand tightness then a 1/4 turn so it should come off easily too, and arent filter wrench's adjustable, the one i have has a chain that locks to the size of the filter.
[Modified by mugenracer, 3:34 PM 8/18/2002]
Old Aug 18, 2002 | 02:43 PM
94gsr's Avatar
Default Re: oil filter question (mugenracer)
Yes, there are adjustable ones, but whether they're adjustable or not, they're still referred to as filter wrench's. If it fits completely around the filter, it's a wrench. If there are two handles that you squeeze together to clamp on the filter, then you're using filter pliers.
namewasdallas
Jun 2, 2010 08:48 AM
Whatislove
Honda Civic (2001 - 2005)
Apr 28, 2009 12:34 PM
yoitz2tone
Acura TSX
30
Jan 22, 2009 07:42 AM
Adankid
Jan 1, 2009 03:12 PM
digdug18
30
Sep 13, 2005 05:12 PM
