Cracked cylinder??
Old Mar 8, 2009 | 03:23 PM
boostedjdmdc2's Avatar
Icon3 Cracked cylinder??
Recently thought i was having headgasket problems because coolant was mixing with the oil, replaced the headgasket, and still mixing and burning coolant. so now im leaning towards a crack in my cylinder wall because Ive got some serious blow by, which looks like white smoke so im guessing the pistons are pushing up that coolant and creating the extra blow by. there is definitely a sweet smell from my down pipe, and on deceleration there is some white smoke that comes out and theres a lot of moisture coming from the exhaust too. im hoping i dont have a cracked cylinder but after replacing the headgasket what else could cause this?
Old Mar 9, 2009 | 06:04 AM
kyden's Avatar
Default Re: Cracked cylinder??
its possible. are the head and block flat?
Old Mar 9, 2009 | 06:41 AM
Walterronny's Avatar
detonation. maybe you get oil inside cylinders..
Old Mar 9, 2009 | 11:42 AM
b21c1's Avatar
did you overheat it? if you did the head or block could be warped.. if its warped putting a new head gasket will not seal it..
Old Mar 9, 2009 | 08:11 PM
it never overheated, the block and the head were checked for straightness, and both were straight. theres no white blow by until the thermostat starts to open
Old Mar 10, 2009 | 09:22 PM
fasterthanueg's Avatar
take off your manifold and see if you have oil in a exhaust port. you might have a broken ringland. hell i had a hole in one of my pistons and it still ran,even made boost.
benjamin
Jul 2, 2022 11:49 AM
derek18105
11
Nov 25, 2012 04:19 PM
Seanakins
Mar 28, 2011 11:00 AM
tony_yang
May 13, 2010 07:18 AM
nota-eg
May 28, 2006 11:04 AM
