Mpi swap few problems
So I did my mpi conversion today in my 88 civic So ill give you a low down of what the specs are
Using a full si engine wire harness
Got everything Wired up correctly started right up! Surprisingly
now for the problem
Runs good except for the idle is crazy out of control I dont know if its due to vacum or what.
I have not bolted up exhaust yet so its open header.... but i dont think that is causing it to idle surge like that
There is a piece missing from my throttle postion sensor but it plugs in and is wrapped with electrical tape.
There is one vacuum hose I don't have hooked up because its supposed to hook into a nipple on the back of the intake mani which i don't have my doesn't have should I tee it into the one that goes into the top of the throttle body ?
Also there is something else i dont know where it goes there is a nipple standing straight up on intake manifold on pass side does that go to other nipple on throttle body ?
appreciate your answers thanks
also i only used a jug of coolant its not full
now for the problem
idk ill prob take pics I put my hand over throttle body and it idled itself out i dont have a spot
for the lil vacuum hose everything else looks right im pretty sure its a vac issue now
Also i dont have a dashpot if that makes a difference also need info on nipple on runner of intake manifold that shoots coolant out of it here is a pic of it http://radekonline.com/download/engine/mani_rail.jpg also i have no intake on the car right now would that effect it ? seems how it doesnt have a mass
mgags7
Jan 30, 2025 08:58 AM
