Crome and starting a new engine for the first time
I will be installing my engine back in my car this weekend. I did new pistons, rods and some head work. I know the best practice is to start it so as not to wash out the rings.
Other than a known good basemap, are there any changes I should make within Crome when starting the car for the first time? Should I lean out the idle maps more?
I have 450cc DSM injectors, walbro 255 pump and the pistons were changed from stock 9.2/1 to 9.3/1 compression ratio. I also have an LC-1 for A/F purposes.
Thanks all
MantisX
Thanks all
MantisX
when you first start the car the A/F should be richer due to the Post Fuel..then ECT/IAT compensations. Once the car warms up yea 14.7 is a good target good luck!
start with a known good map and go from there. If you have a wideband then you are all set.
Thanks guys for the info! I was able to get the car primed and started correctly. Now to get her tuned.
Thanks everyone
MantisX
Thanks everyone
MantisX
