help..
Old Mar 3, 2009 | 07:25 PM
Costa's Avatar
Default help..
hey guy's im new to this forum and i just needed some guidence ( sorry for spelling )
ok i have a 92 civic dx with
-d16z6 motor
-stock everything else.
ok first of all, the motor when running for a long time feels like its choking on gas then it dies and i have to wait till the motor is cold before i start it.
my throttle cable is sticky so its not accurate at all.
my vtec doesnt even work, i have no clue why maybe i need a new solinoid, im not sure.
i have a p28 computer, but my map sensor on my throttle body is melted so i used the stock firewall map sensor, also my throttle positon sensor is melted.
i dont know what i should do to fix my problems, or where i should start. i heard d-seires motors can take turbos and such, and i want to look into that. first i want to know what i should do. then work my way up from there.
please feel free to leave anything, so i can fix this car. and make it worth keeping and having fun with.
-Matt
Old Mar 3, 2009 | 07:52 PM
Former User's Avatar
Default Re: help..
The MAP sensor and TPS are extremely important for your engine to run properly. Replace the damaged sensors with new ones ASAP.
Does your CEL work? If not, fix it and pull all of the codes from the ECU.
Old Mar 3, 2009 | 08:05 PM
Costa's Avatar
Default Re: help..
i think im going to buy a new throttle with new sensors, do you know a good throttle i can pick up? maybe give me some more power?
whats a CEL?
thanks alot
Old Mar 3, 2009 | 08:10 PM
Default Re: help..
Originally Posted by Costa
whats a CEL?
Click here.
Old Mar 3, 2009 | 08:17 PM
trustdestruction's Avatar
Default Re: help..
whats a CEL?
a new throttle body won't give you any gains unless the intake manifold is port matched or bigger. if the intake manifold is smaller than the throttle body, you're just going to cause more restriction and disrupt the natural flow of air.
CEL=check engine light
did you wire up VTEC when you swapped in the D16Z6?
Old Mar 3, 2009 | 08:22 PM
Costa's Avatar
Default Re: help..
21 VTEC spool solenoid valve
10 IAT - intake air temperature sensor (sometimes this one comes up)
but mostly 21..
what kind of manifold should i get with a good throttle, throw in some injectors? with a new fuel rail?
Old Mar 3, 2009 | 08:25 PM
Default Re: help..
high pressure fuel rails are wasted $$$ unless you're making a ton of power.
code 21 explains why VTEC doesn't work. once again, did you wire VTEC?
for the manifold, i've heard great things about the Edelbrock PerformerX. However, I recommend getting something like an OBD1 B18 (60mm) throttle body and just getting your intake manifold ported. A skunk2 throttle body which is 70mm is not necessarily good because there is a point where the throttle body is too big. 60mm would probably be optimal.
and you don't just "throw in" injectors. you only want to supply as much fuel as you can burn.
before you do any of these modifications, you really need to search and read up on it. i read up on most stuff for my car (performance wise) for months before i decide what i want.
Old Mar 3, 2009 | 08:28 PM
Costa's Avatar
Default Re: help..
yes it's wired um the plugs on it work aswel i checked the voltage. when the car tries to hit vtec it feels slugish and kinda pulls back and it get really loud, then the engine light comes on.
Old Mar 3, 2009 | 08:30 PM
Default Re: help..
Hmmm...If the MAP sensor and TPS were completely trashed, I expected that you would have retrieved CEL codes for both sensors.
Old Mar 3, 2009 | 08:32 PM
Costa's Avatar
Default Re: help..
i know thats what im wondering why is the sensors melted to S**T and they still work. they are probibly giving the wrong info to the computer about air and my throttle position.
Old Mar 3, 2009 | 08:35 PM
Default Re: help..
Prior to replacing, you might want to do the electrical tests described in the service manual for both sensors.
Old Mar 3, 2009 | 08:40 PM
Costa's Avatar
Default Re: help..
ok i will try that and get back to you. thanks alot
Old Mar 3, 2009 | 08:45 PM
Default Re: help..
Regarding the VTEC problem, is the engine oil low? Have you cleaned the filter in the VTEC spool valve?
Old Mar 3, 2009 | 08:50 PM
Costa's Avatar
Default Re: help..
i just changed the oil... vtec spool valve? i have to take that off and clean it? do i need a gasket?
Old Mar 3, 2009 | 08:51 PM
Default Re: help..
vtec spool valve is a fancy name for the solenoid.
Old Mar 3, 2009 | 08:53 PM
Default Re: help..
Trust is correct.
Old Mar 3, 2009 | 08:56 PM
Costa's Avatar
Default Re: help..
oh ok so i wont need a new gasket? or seal?
nuginu
K Series
Aug 17, 2013 11:26 AM
A90Civic
Jun 9, 2009 01:36 PM
SVOboy
Mar 26, 2006 11:48 AM
kechup2eg6
Aug 10, 2005 07:47 PM
DeadVet
Nov 5, 2004 05:22 AM
