needing help
needing help
I have a 93 civic dx with a d15 non v-tec motor and swapping a d16z6 motor in. I'm missing a plug for the MAP sensor on top of throttle body from harness of my civic to new motor. Any one can help that would be great! thank you
Resident Gearhead
Re: needing help
The '92-'95 DX D15B7 (all DX I believe) has an external MAP sensor, you can find it mounted to the firewall next to the fuel filter. There is a vacuum line that goes from the throttle body to that MAP sensor.
When you drop in the D16Z6, remove the connector on the firewall MAP and plug it into the MAP on the throttle body of the D16Z6. Done.
You can now ignore the MAP on the firewall or remove it. You won't need it.
Mikes2000civicsi
06-04-2011 09:02 PM
