Classic Hondas All Pre-1988 Hondas.
Knocking noise continue even with head repaired?
Old Mar 1, 2009 | 01:24 AM
user 69782342442's Avatar
Default Knocking noise continue even with head repaired?
My crx 86 makes a knocking noise when ever it's being revved up... I was hoping it was the cam problem as I had the cam, head, valves checked and fixed from an auto shop, I still have a knocking problem (but less problem this time as it was leaking oil in combustion chamber and blown head gasket). It appears to be that the head is okay and healthy, valves are healthy, but whenever I start the car up it makes some strange knocking noise from the engine I am very desperate now that I had put a lot of money for a head job... and what could the knocking be exactly from ? also should I post a video of how it sounds if it would make a good difference? If so, I'll record a video of how it runs by tomorrow then...
Old Mar 1, 2009 | 06:35 AM
Lt. Dan's Avatar
Default Re: Knocking noise continue even with head repaired?
Probably gonna be a main bearing....
Old Mar 1, 2009 | 11:56 PM
Crap, if that's so... would the crankshaft need to be replaced???
Old Mar 2, 2009 | 01:18 PM
1grex's Avatar
..or a rod bearing, either way, you may be able to get away with new bearings alone, or regrind a journal or two...the crank is junk only if its warped or cracked or if you don't trust your machine shop
Old Mar 2, 2009 | 05:44 PM
Ticking problems:
http://www.youtube.com/watch?v=Qdm2xks4XlI
RPM problem?:
http://www.youtube.com/watch?v=QGhhpw2AUxo
In the rpm problem... I just see the needle jumping up and down strangely but I am not sure what that is about... and don't be fooled i gassed it several times to show you if it makes a difference...
Just thought I'd show these... and I'm hoping it's just the bearings to be replaced because I'm having stupid financial issues here...
Old Mar 2, 2009 | 11:05 PM
gutted's Avatar
sounds like a main or rod bearing issue. theres a possibility of the crank & block needing to be resurfaced depending on the damage. has the car always been knocking? or did you run it with no oil?
i would make the shop pay for it IF they were the ones who recommended you getting all the work done to the head.
Old Mar 3, 2009 | 12:14 AM
Well, the thing is, with the head being repair was a different story and the guy only worked on the heads so there's no way I can make him pay (one man running business)... Well it started making it's noise when I haven't given it oil change ever since i got the car (like ran the car without oil change for almost a year which approximately ran 10,000 miles on it) but was when my father had been using it in the first place so I didn't know the story of the car very well as he did until I got these frustrating problems in the way... So I believe it was because of no oil change being involved... How long can I drive it until it can no longer handle??
Old Mar 3, 2009 | 12:27 AM
jcool88's Avatar
New User
Ok here is an easy way to see if you have spun a bearing is to drop your oil pan or drain the oil into a container that you can look in to then if you dropped the oil pan look in to it to see if you see any kinds of metal shavings or chunks or if you drain it your going to have to stick your hand in the oil to feel around for metal or strain it because if your finding piece of metal its a good sign you spun a bearing
Old Mar 3, 2009 | 12:48 AM
I'll have to try that. One thing by the way, when I had the head being repaired, the man who owned the repair shop said he fixed my cam, which was "pitted" not sure if that also gives a clearer idea of the car.
Old Mar 3, 2009 | 01:04 AM
jcool88's Avatar
New User
Well that happens to cars over time because of high miles and insufficient lubrication like not changing your oil for 10,000 miles it is not the best thing to do because the oil starts getting thicker and doesnt move threw out your motor like its suppose to.
Old Mar 3, 2009 | 10:09 AM
KILLAB17VTEC's Avatar
Genetically Gay
i think ticking is ok for an 86crx.you might need a lil valve adjustment thats all.
Old Mar 3, 2009 | 11:47 AM
It has been recently adjusted about a week ago already, and no it never made this kind of noise until a month ago.
Old Mar 3, 2009 | 11:54 AM
jcool88's Avatar
New User
lol im just sayin that sounds more then ticking its knocking
Old Mar 4, 2009 | 12:04 AM
JDMB16DA6's Avatar
Rod knock. Maybe piston slap? Time to pull the block and send it in.
-Brian
S1000RR
Dec 5, 2012 11:01 PM
ddtfrom626
Jun 14, 2008 12:07 PM
hotinteggy
Mar 9, 2007 03:21 PM
Wes90civic
Mar 14, 2004 06:14 PM
Logon
Mar 28, 2002 07:19 PM
