Vtec problem??
Old Feb 28, 2009 | 12:37 PM
vLad11591's Avatar
Default Vtec problem??
I have a 93 eg coupe, with a b16 i/h/e.
Basically everytime i hit vtec the speedometer goes retarded (goes from like 0-120 and back and forth) And sometimes when i hit vtec continuosly it gives a check engine light, but when i turn the car off and on its perfectly fine. I also have a small idle from like 1000-1500 when im at a light, or it seems when i turn off the ac/heat theres no idle.
Any help would be appreciated
Old Feb 28, 2009 | 12:40 PM
blueg6's Avatar
Default Re: Vtec problem??
when the CEL is on does vtec still engage?
Old Feb 28, 2009 | 02:53 PM
vLad11591's Avatar
i think it does? i didnt even get to check it but im pretty sure it does
Old Feb 28, 2009 | 05:23 PM
trustdestruction's Avatar
sounds like two wires are exposed and touching somewhere. possibly the VTEC wire and the speed sensor wire.
Old Mar 1, 2009 | 04:14 PM
vLad11591's Avatar
bump? would i have to pull the engine to check this?
Old Mar 1, 2009 | 04:18 PM
just trace the wires and look for exposed wires. the touching wires are going to be somewhere between the ECU and the engine/tranny.
Old Mar 1, 2009 | 04:55 PM
joelmatt89's Avatar
have you tried to pull the cel or is your ecu not storing it
Old Mar 1, 2009 | 06:07 PM
vLad11591's Avatar
IDK? my cel is on only when i run vtec consistantly.. More like lets say 6-10 times.. Its not a huge problem because i still can DD it with no problem, but i still would like to know the problem.. When i do turn off the car and back on its off and its not throwing me any codes, just giving me the light.
Old Mar 1, 2009 | 06:58 PM
citizenEK's Avatar
change or check the wiring at the VSS on the tranny, if it is loose or bad that will cause your speedo to bounce crazy like that and if your in VTEC and your speedo has zero for a reading it will shut down ur VTEC causing it to throw a code
Old Mar 2, 2009 | 07:24 PM
vLad11591's Avatar
thanks ill try that buymp
Old Mar 3, 2009 | 07:11 PM
vLad11591's Avatar
bump?
Old Mar 3, 2009 | 07:26 PM
vLad11591's Avatar
i found out another problem, im idling 1-2 rpm, and im literally getting terrible MPG.. sum1 help me out.?
Old Mar 4, 2009 | 05:32 AM
vLad11591's Avatar
bump
tttt
Old Mar 4, 2009 | 09:21 AM
why are you bumping this?
have you tried the suggestions? are you going to tell us if you've tried the suggestions?
it's hard to give more input when you don't tell us what has and hasn't helped.
Rooftop voter
Aug 1, 2009 01:58 PM
BILLisCHILL
Apr 19, 2008 08:47 AM
juanintec
Aug 10, 2007 05:11 PM
spoonzdelsol
Jan 9, 2006 08:04 AM
SLOAZZ95
Aug 13, 2004 08:31 AM
