Vtec not engaging. Can't pull codes.
Old Jul 24, 2009 | 08:10 PM
Rooftop voter's Avatar
Default Vtec not engaging. Can't pull codes.
Like the title says, Vtec won't engage. I have a check engine light on, which I would assume is the reason why vtec isn't working. I tried jumping the codes but when I turn the ignition on, the CEL comes on for like half a second, then goes out and doesn't come back on again. As soon as I pull the wire out of the plug, it comes on and it stays solid. WTF do I do now? I have a Hondata s200, is there a way to pull the codes off of that, and if so, what's required? Will I have to go back to my tuner for them to get the codes? Is there another way I can jump the codes? Any advice? I've already checked the oil and there's pleanty so I know that's not the culprit.
Old Jul 24, 2009 | 09:54 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Vtec not engaging. Can't pull codes.
this happens to me on my s100 you pretty much need your tunner to check it but just try to find the problem check the wires going to the vtec solinoid and also anyother plugsr/sensors that may have came loose look under the dizzy between the vtec sol. theres a plug that gets disconected sometimes. gl
Old Jul 25, 2009 | 04:40 AM
Thanks, I'll do that when I go out to my car later. Sucks there's no other way to get the codes than going to the tuner.
Old Jul 25, 2009 | 05:51 AM
Went and checked this morning, nothing is unplugged. I've had a suspision that my O2 sensor was going bad, if it is bad would this be something that would keep me out of VTEC? Also, when you fix whatevers wrong, will the CEL turn off, or does it need to be reset?
Old Jul 25, 2009 | 02:30 PM
Bump for info.
Old Jul 25, 2009 | 09:44 PM
bump
Old Jul 26, 2009 | 05:10 PM
boarding2008's Avatar
My CEL is on in my db8 for the O2 sensor and vtec still engages.
Old Jul 26, 2009 | 05:22 PM
follie gatts's Avatar
usually, the ECM needs to be reset for the code to clear. just pull the two fuses under the hood for ECM and radio backup for 5 minutes. make sure you've got your radio code.
Old Jul 26, 2009 | 06:01 PM
I disconnected the battery, but only for about a minute or so and it didn't do anything. I assume disconnecting it for 5 minutes or more is required to reset everything?
Old Jul 26, 2009 | 06:17 PM
http://www.team-integra.net/sections...p?ArticleID=82
Old Jul 26, 2009 | 06:25 PM
94VTEC2TONE's Avatar
your not gettin vtec so you need to pull codes are u ****ing serious dude? why not check the vtec solenoid nby takin it out see if its plugged. also why not check the wiring for voltage and evertyhing hmm instead of looking and sayin its good. and an o2 sensor knocking out vtec is impoosible
Old Jul 26, 2009 | 06:39 PM
lol after he fixes the CEL problem he hopefully wouldn't just give up at that point.
Old Jul 26, 2009 | 06:44 PM
Well, you don't need to be rude about it. I would still like to be able to see what codes are present just in case anything else needs to be done. I will be more thoroughly checking everything once I get some time. I guess I can rule out the O2 sensor now as well, thanks for the info.
Old Aug 1, 2009 | 01:58 PM
importrepairguy's Avatar
o2 mil shouldnt contribute to a lack of vtec engagement.
Check oil level first! Make sure your speedo is functioning and or plugged in VSS will not allow engagement. If it has oil - and if you can chk. oil pressure than do it. If not, look under car and make sure the bottom of your oilpan isnt banged in, from jacking, speedbumps, etc... If it is, and you can't pull any MIL codes, then drop oilpan bang flat from inside with rubber mallet, check pick-up tube for damage or blockage, straighten if neccessary at the pick-up screen and re-install.
After all this - if you find nothing, lite it on fire! No im kidding, just re-post your finding if anything.
Cheers
gsrboost737
Aug 7, 2008 06:38 AM
BILLisCHILL
Apr 19, 2008 08:47 AM
thangbui
Oct 23, 2005 08:05 AM
05r1
16
May 20, 2005 08:21 AM
veilsides2000
Nov 27, 2004 11:18 PM
