O2 Sensor question
Old Feb 28, 2009 | 12:20 PM
mattkins91's Avatar
Default O2 Sensor question
I have a 99 civic ex and just got a tsudo catback put on it and now my check engine light is on and i read the code and its the o2 sensor. So do you guys think that maybe the fried my 02 sensor when they were using the mig welder or do you think i just need a dummy sensor? Thanks for any help
Old Feb 28, 2009 | 12:26 PM
Jimmy's Avatar
Global Moderator
Default Re: Help!!!
https://honda-tech.com/forums/showthread.php?t=2407755
Old Feb 28, 2009 | 12:47 PM
mattkins91's Avatar
Default Re: Help!!!
alright my bad sooooo can anybody help me
Old Feb 28, 2009 | 12:54 PM
tiptopEBPcivc's Avatar
Default Re: Help!!!
you prob need a fake o2 sensor, ""dummy" whatever, its just going to happen, if you think they have fried it, pull it out and test it...... how do you test it? i have no idea but its prob. because of the new kit. have you tryed getting the code cleared? autozone, and advanced auto will do it for free.......... but dont let it go like that for long without fixing it.... you'll use up a **** ton of gas
Old Feb 28, 2009 | 01:00 PM
KillBot's Avatar
Default Re: Help!!!
Primary or secondary o2 sensor code?
Old Feb 28, 2009 | 01:09 PM
mattkins91's Avatar
Default Re: Help!!!
so if i got a dummy would i still be able to pass inspection?
Old Feb 28, 2009 | 01:10 PM
mattkins91's Avatar
Default Re: Help!!!
im not real sure the guy at autozone just told me it was my 02 sensor....i think the code was p0104 if that helps.
Old Feb 28, 2009 | 01:15 PM
mattkins91's Avatar
Default Re: O2 Sensor question
Also it seems like i cant hear or feel my vtec crossover since i got my catback put on
Old Feb 28, 2009 | 06:51 PM
mattkins91's Avatar
Any help would be greatly appreciated
Old Feb 28, 2009 | 06:54 PM
KillBot's Avatar
Default Re: Help!!!
p0104 is not an OBD-II code. Getting the code should make this a piece of cake.
Old Feb 28, 2009 | 07:25 PM
mattkins91's Avatar
Default Re: Help!!!
Alright first thing tomorrow morning im going to get the code read again and post it on here.
Old Mar 1, 2009 | 09:16 AM
mattkins91's Avatar
ok so i got the code and its p0141 and it says that a malfunction exists in the heater circuit for oxygen sensor 2 in bank 1.
Old Mar 1, 2009 | 10:18 AM
GetawayInMoscow's Avatar
That's your secondary O2 sensor, don't worry about the bank stuff, that's for V6's and V8's (etc.).
Are you running a test pipe?
Old Mar 1, 2009 | 12:04 PM
mattkins91's Avatar
ok no im not i still have the oem cat
Old Mar 1, 2009 | 04:29 PM
KillBot's Avatar
As said above, this is a code for the O2 sensor screwed into your cat
Check and make sure no wires were cut/damaged/pinched.
Reset the ECU and check to see if the code comes back.
If everything is good and the code comes back, you might need a new O2 sensor.
If you get an O2 sensor, go ahead and make sure it is a Denso brand. There are very few OBD-II hondas that like the Bosch replacements sold at most auto parts stores. I would check Majestic Honda's website for a good price.
Old Mar 1, 2009 | 06:01 PM
mattkins91's Avatar
ok so its not the one thats close to my oil pan? Its the one plugged into my cat? and how exactly do i reset my ecu?
Old Mar 1, 2009 | 06:25 PM
KillBot's Avatar
It is the one plugged into your cat.
You can pull the ECU fuse, or disconnect the battery (just make sure you have the radio code).
I would recommend pulling the fuse.
Old Mar 1, 2009 | 06:37 PM
mattkins91's Avatar
Ok i just looked for a sensor on majestic honda and i couldnt find one and are you talking about the security code for the radio
Old Mar 1, 2009 | 07:01 PM
KillBot's Avatar
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
^Looks like #27
Yes, the security code for the radio.
Old Mar 1, 2009 | 07:15 PM
mattkins91's Avatar
^Looks like #27
alright thanks alot for all your help i really appreciate it.
Old Mar 1, 2009 | 07:18 PM
KillBot's Avatar
No prob, and good luck.
Old Mar 1, 2009 | 09:01 PM
TheJGB3's Avatar
Yes #27 is what you need
36532-P2P-A01 SENSOR, RR. OXYGEN $212.72
Old Mar 2, 2009 | 05:09 AM
mattkins91's Avatar
Is #27 considered the sensor after the cat?
Old Mar 2, 2009 | 04:26 PM
KillBot's Avatar
After the cat?
Secondary O2 sensors on an EK EX are screwed into the cat itself...there are no sensors after the cat.
In the above diagram, #40 is the Primary O2 sensor, and #27 is the secondary sensor.
Old Mar 3, 2009 | 06:08 PM
mattkins91's Avatar
ok well i went to autozone and they asked me if i needed the one before or after the cat
Civic98KH
15
Dec 10, 2012 08:26 PM
amej8
Jul 11, 2006 06:25 PM
cu3tip
Oct 18, 2004 09:45 PM
cu3tip
Oct 18, 2004 08:26 PM
GSRacer
Oct 8, 2001 06:59 AM
