HELP transmission problem after install
Old Feb 26, 2009 | 10:03 AM
ftrms's Avatar
Default HELP transmission problem after install
So yesterday i put the tranny on the car, never done it before but it seemed like it went on smooth, then i get into the car and it only goes into 1st and 2nd gear and reverse, I mess with it and get it in 3rd now it wont get out of 3rd. Did I do something wrong when installing it? This is my daily driver so any suggestions would help!
Old Feb 26, 2009 | 10:06 AM
EK9r!der's Avatar
Default Re: HELP transmission problem after install
it could possibly be a bad tranny, was your clutch and pressure plate in good conditions when you took it out.
Old Feb 26, 2009 | 10:12 AM
ftrms's Avatar
I didnt take that off my old tranny had a bad input shaft bearing so i just replaced it, but the clutch and pressure plate only has about 15k miles on it
Old Feb 26, 2009 | 10:14 AM
EK9r!der's Avatar
umm... when that happened to me it was a bad clutch and pressure plate, is it cable or hydro?. if hydro i dont know if it would help, but try bleeding the slave cylinder.
Old Feb 26, 2009 | 10:17 AM
ftrms's Avatar
its hydro, could i have put the throwout bearing and fork in wrong i dont think i did but thats the only thing i really touched thats inside the tranny
Old Feb 26, 2009 | 10:39 AM
ftrms's Avatar
so i just went back out there it goes into gear except for 4th and 5th
Old Feb 26, 2009 | 10:42 AM
EK9r!der's Avatar
umm... idk maybe you didnt install everything right when you were putting the transmission back together (as far as all the gears inside the tranny)...
Old Feb 26, 2009 | 10:55 AM
ftrms's Avatar
i didnt take it apart. My old tranny had a bad input shaft bearing so i put a different one on. I put the car back on the ground and had tried to drive it in first to see if it would drive and it just revs up when i try to drive it does that mean my clutch is bad? before i took it apart it acted like the clutch was slipping really bad but i was told that couldve just been the input shaft bearing cause we knew it was bad already
5ltreater
Apr 19, 2005 12:40 PM
rocco
Jul 27, 2003 11:41 PM
b16pwrcrx
Jun 28, 2003 11:02 AM
BoostedED9
Nov 13, 2002 05:47 AM
