bled clutch..still no pressure....
ok, 3rd is gone in tranny and alittle while ago i started to loose pressure in clutch peddle..could this be my pressure plate is gone..i mean my clutch peddle goes compl. to the floor and wont come back..wont go in gear...
please help me out here ht members..
Re: bled clutch..still no pressure.... (5ltreater)
its possible,
Remove the rubber boot on the tranny, check for play everything should be tight. IE the fork should be putting pressure on the piston forcing it back into the cylinder, so if its lose there then your pressure plate is messed up or you have a bent fork. Either way trannys got to come off. if its all tight then its a problem in the hydro system somewhere.
Re: (5ltreater)
it's probably not the pp, sounds like a hydraulic problem. a bad clutch master cylinder ruined my 3rd gear too, try master and slave.....then bleed it for 3 days straight. you'll be fine.....except for that 3rd gear
Hippslsvtec18
05-21-2010 10:54 AM
JDM_SOHC
36
05-21-2007 03:50 PM
ActiveAero
03-03-2007 12:56 PM
