Crazy Idea Again let me know what you think
Old Feb 23, 2009 | 05:22 PM
Navy_CRX's Avatar
Icon6 Crazy Idea Again let me know what you think
Alright guys...
Another one of my ideas that I had last night. is it possible to spool a large turbo with a small turbo. IE. I have a b18c with a small turbo (50 trim t3) run like normal except the compresser output is attached to the turbine of a large turbo (GT42) the exhaust side of the large turbo is re routed to the intake of the small or large turbo (havent realy thought this far) let me know what you all think.
Just a crazy idea
Eddie
Old Feb 23, 2009 | 05:30 PM
Karl Buchka's Avatar
Default Re: Crazy Idea Again let me know what you think
That's called compound charging and is very common among hi-po diesels.
Old Feb 23, 2009 | 05:34 PM
Navy_CRX's Avatar
do you think it would be possible on one of our little honda motors.
Old Feb 23, 2009 | 05:59 PM
Sure. I think the main issue is reliable boost control. You can make a lot of boost relatively quickly, but the problem is getting it to stop boosting at some point.
An example of the boost response with compound charging is a cool 7m-gte Mk3 Supra in Sweden. It's got an Eaton M90 feeding a Holset HX55.
Boost at rpm:
0.5 bar at 1800
1.0 bar at 3000
1.5 bar at 3500
2.5 bar at 4000
3.0 bar at 4300
and redline at 8000. And that's in 5th gear.
Old Feb 23, 2009 | 06:15 PM
HiProfile's Avatar
The problem with an SC feeding a turbo is the theory that makes a normal possitive displacement device work. X amount of air can be pushed through - or pulled through. It needs to be run at a very high speed relative to what it was designed for. Reverse it (turbo then SC) and run the SC at lower boost (peak efficiency), and you don't suffer from that issue.
Compounding 2 devices works well if you want some crazy boost for a diesel. Gasoline eninges prefer flow to pressure, though, or at least not crazy pressures. The main problem with doing it on a Honda is space constraints. A truck's engine bay has much more space for 'exotic' equipment like that.
Old Feb 23, 2009 | 06:33 PM
Bailhatch's Avatar
Originally Posted by Navy_CRX
Alright guys...
Just a crazy idea
Eddie
That is not compound anything. I think the others may have missread.
Old Feb 23, 2009 | 07:27 PM
GT35R_EF's Avatar
Make mine whatever you want
You mean something like this?
Old Feb 23, 2009 | 08:09 PM
dh-r's Avatar
Omg!
Old Feb 23, 2009 | 08:32 PM
streetracer6rpt's Avatar
waste of money....
Old Feb 23, 2009 | 10:31 PM
GT35R_EF's Avatar
Originally Posted by streetracer6rpt
waste of money....
lol I'd have to say I tend to agree on that one. But, very cool anyways.
Old Feb 24, 2009 | 01:19 AM
Navy_CRX's Avatar
you see what im thinking is have a smaller turbos boost (compresser output) feeding the larger turbos turbine side. im not talking a turbo supercharger. im thinking that here will be no ehaust pullses to wory about the small turbo will spool quickley to feed the larger turbos turbine without missing a beat therefore eliminating a lot of lag acompied by a large single turbo.
crxkid24
Dec 19, 2011 12:52 AM
Mr.DC2TurBo
Mar 26, 2004 10:32 PM
ASHY-ELBOW
Oct 6, 2003 09:20 PM
B18C-Hatch
Jan 20, 2003 04:59 PM
LOwrestling2001
Nov 27, 2002 09:59 AM
