APR studs Torque sequence for D series
Old Feb 19, 2009 | 03:42 PM
civic_turbo_wannabe's Avatar
Default APR studs Torque sequence for D series
Im building a d16 turbo and i cant find anyone who can agree on a torque setting for the arp studs.
Ive decided on this, 20Nm, 40Nm, 60Nm, 88Nm
total 65 lbs ft
Does this sound right? anyone?
Old Feb 19, 2009 | 03:57 PM
pemd5555's Avatar
Default Re: APR studs Torque sequence for D series
theres a sequence to torquing the head down. If i knew how to load pics up id show you. Also you torque it in steps. Dont use newton meters. everything is in foot pounds in americaaaaa
Old Feb 19, 2009 | 04:18 PM
Jas9848's Avatar
arp studs on a d might be more than 65 lb/ft, might not. start tightening in the middle and work your way out and go back over them. work in steps
Old Feb 20, 2009 | 10:33 AM
Default Re: APR studs Torque for D series
I know the sequence i meant the torque setting. If thats so how come the snap on torque wrench which im using, made in the usa has only Nm on it?
Old Feb 20, 2009 | 10:37 AM
Okay okay,
Im doing it in stages and i'll tell you in pounds feet
1st step - 15ft.lbs
2nd - 30ft.lbs
3rd - 45ft.lbs
4th - 65ft.lbs
That sound right to anyone? Thanks
Old Feb 20, 2009 | 11:25 AM
Davus's Avatar
Originally Posted by civic_turbo_wannabe
Okay okay,
1st step - 15ft.lbs
2nd - 30ft.lbs
3rd - 45ft.lbs
4th - 65ft.lbs
Sounds right. The stuff I read didn't include the 3rd stage, I just went 15, 30, 62 on my ARP head studs (d16y8), but the extra step should be beneficial for peace of mind.
Old Feb 20, 2009 | 11:58 AM
cool thanks... so you think i should go 62 max? im sure 65 wont do it any harm right? surely give it more clamping force?
Old Feb 20, 2009 | 05:52 PM
NastyHabitzCRX's Avatar
hmmm, i went 35,55,75ft lbs. had these i same studs on 3 different blocks and never had a problem.
Old Feb 20, 2009 | 06:45 PM
teamworxek9's Avatar
get a manual for the car it will answer your questions, or call arp.
nitroice40
Apr 19, 2008 05:19 PM
slo_b18
Jan 30, 2008 08:47 AM
Jdmb16sir2
Jun 10, 2007 05:50 PM
djtony5
Nov 17, 2005 02:48 PM
