Need help! stripped bolt. searched
Old Feb 19, 2009 | 02:00 PM
UserX826's Avatar
Default Need help! stripped bolt. searched
This bolt is stripped to hell. It WILL NOT come out. You can see because of the angle i can't get a drill to it. Sockets, crow's foots, and combos will not work. I've put locking pliers on it and tightened them down as much as they will go and it still won't come out. It's taken 3 days and more than half a can of PB Blaster. Someone please tell me you have an idea.
Old Feb 19, 2009 | 02:14 PM
ifIexplode's Avatar
Default Re: Need help! stripped bolt. searched
Can you get a dremel down there?
If so grind each side flat so you can get a wrench on there, or an Adjustable then put a piece of pipe on the end for leverage. That bolt looks pretty mangled.
Old Feb 19, 2009 | 02:16 PM
roadsqueegy95's Avatar
ya dremel it and use a wrench or if u could just cut a straight line and put a straight head screw driver to it!! or rachet with stright head attachment, hate rounding off bolts
Old Feb 19, 2009 | 02:18 PM
Former User's Avatar
My local Sears sells special sockets for removing stripped bolts. Other tool stores likely also sell them.
Old Feb 19, 2009 | 02:21 PM
UserX826's Avatar
http://www.sears.com/shc/s/p_10153_1...+Taps+%26+Dies
That what you're talking about?
Old Feb 19, 2009 | 02:24 PM
Yes, I've seen the ones packaged in the red box.
Old Feb 19, 2009 | 02:28 PM
UserX826's Avatar
Alright. Don't really have much extra cash to pick up a dremel at the moment, so i'm gonna give these a shot. Thanks guys. I'll post how it goes.
Old Feb 21, 2009 | 11:50 AM
UserX826's Avatar
Ok. The bolt outs didn't help. Could be because the bolt was so mangled, but it just kept slipping off. I eventually had to go get a dremel and cut/grind it out.
Old Feb 21, 2009 | 11:55 AM
Glad to hear you fixed the problem. If the bolt-out socket slips, you then should try the next size smaller socket. In some cases, you might have to tap the smaller socket on with a hammer.
Old Feb 21, 2009 | 02:46 PM
94EG8's Avatar
Seagull Management
Thats why you keep metric and standard sockets, standard sockets will generally fit between two metric sockets IE 3/8 is bigger than 9mm and smaller than 10mm (also usually just the right size for severly rusted 10mm bolt heads
Old Feb 21, 2009 | 10:02 PM
UserX826's Avatar
Yeah. I think the bolt was too far gone. I tried one lower size, but it wouldn't fit at all. I tried to hammer on the right size, but as you can see i didn't really have much room to work with.
bobbyeg6
Apr 26, 2010 04:11 AM
00DC2
Jul 22, 2009 06:18 PM
tpot90
Apr 5, 2008 09:46 AM
Yelowfever
Jul 10, 2007 08:06 PM
Methane2k2
Dec 15, 2004 12:57 AM
