Help...Im New
Old Feb 17, 2009 | 09:26 PM
kevinf_69's Avatar
Default Help...Im New
Hello everyone I have a prblem with my crx. It has a zc engine. evertime i press the gas you hear a little bell noise. Another problem is when i go into gear it sounds like somethings rubbing or scraping . please help Thank you
Old Feb 17, 2009 | 11:34 PM
h224thgensedan's Avatar
Default Re: Help...Im New
bell noise? Does your car have an aftermarket intake on it? How hard do you have to press the gas to hear the sound?
Old Feb 17, 2009 | 11:36 PM
ALLxMOTOR EG's Avatar
Vietnamese!
When you go into gear do you hear your tranny grind?
Old Feb 18, 2009 | 05:55 AM
kevinf_69's Avatar
This is going to sound tupid but it sounds like a cricket. when im in speed i just hit the gas a little and you hear it but it goes away when i let off th gas. yes i do have an aftermarket intake. It doesnt grind when going into the gear it sounds more of metal rubbing sound. Like a bad throwout bearing??
Old Feb 18, 2009 | 06:05 AM
Zero rex's Avatar
do u hear the noise when u step on the clutch while u are driving?
Old Feb 18, 2009 | 06:11 AM
kevinf_69's Avatar
no i do not it goes away after I speed up in any gear.
Old Feb 18, 2009 | 06:20 AM
Zero rex's Avatar
wat about when u have the car park do u hear the noise ?
Old Feb 18, 2009 | 06:25 AM
kevinf_69's Avatar
noyou dont hear it when in neutral
Old Feb 18, 2009 | 06:47 AM
Zero rex's Avatar
then is not ur throwout bearing is some ells.
Old Feb 18, 2009 | 07:21 AM
jhammond_82's Avatar
Reject Papi
heat shield ftw!
Old Feb 18, 2009 | 07:30 AM
kevinf_69's Avatar
no i thought it could of been that to but i checked it. It sounds like its coming from the tranny
Old Feb 18, 2009 | 07:38 AM
George777's Avatar
The "cricket" sound is more than likely your intake. Mine did it all the time. Even changing the filter didn't help it, so I just turned my radio up so I didn't hear it anymore.
Old Feb 18, 2009 | 07:41 AM
8dxhatchy8's Avatar
is it like a little whisteling sound when ur pedal is in a certain position???
Old Feb 18, 2009 | 08:03 AM
kevinf_69's Avatar
lol yea its like a little high pich sound.
Old Feb 18, 2009 | 08:13 AM
Yea one thing you could look at is make sure all of your clamps on your intake are tight and there isnt a small leak somewere whistleing. The intake on my d15 when it was still in my car would sound like a boat horn when i shut the car off.
Old Feb 18, 2009 | 09:23 AM
lancerkid06's Avatar
almost every car i hve had whistled when i put a intake on it .. but my new hatch has a full wire tuck and the map sensor was on the pass floor board area and the thing besides the map sensor i think its the purge solenoid valve ... it didnt have a hose connected on it and it would whistle .. so i just put that back in the engien bay and re-run hoses and it stopped the whistle
Old Feb 18, 2009 | 10:09 AM
ef yu's Avatar
i believe its the transmission itself. mine does the same thing.
"whines" in every gear if you keep it at a steady speed.
don't know what can fix it beside having the tranny rebuild but music helps me out during long road trips.
Old Feb 18, 2009 | 10:11 AM
kevinf_69's Avatar
it doesnt wine. its a scraping sound only at the begining of every gear. it goes away when i hit the gas
Old Feb 18, 2009 | 10:17 AM
shyguy4no1's Avatar
Have you checked the fluid levels??? It could be caused by either improper level of transmission fluid or what type of transmission fluid. Its worth a shot. Or it basically can be something that you will always hear.
Old Feb 18, 2009 | 10:50 AM
can you hear it when just sitting still and shifting the gears .. cause mine was scraping my exhuast before
Old Feb 18, 2009 | 11:44 AM
8dxhatchy8's Avatar
my whistleing sound is my intake, if i adjust the idle control it goes away, if its set kinda low when u accelerate it will whistle. kinda sounds like its a really faint turbo spool.....doesent bother me! lol.
DeLSoLRo
Jun 1, 2011 08:44 PM
globy123
Feb 22, 2008 04:03 PM
onefastrx7turbo
Oct 15, 2005 12:31 PM
