Need help with tranny noise?
Old May 30, 2011 | 08:21 AM
DeLSoLRo's Avatar
Default Need help with tranny noise?
95 del sol with 170k, I dont know what has/hasn't been replaced on it.
Whenever im in low gears the car will make like a grinding noise (like marbles rubbing into each other really fast) when giving the car gas, if i press the clutch in it goes away once fully in, once i re-engage it starts making it again when i accelerate or let the gas off but if i hold the rpm/speed at a constant speed it doesn't do it. if i let go of the gas while in gear it sounds 10x worse.
Long story short, Noise only happens when clutch is engaging/disengaging or when in 1st/2nd and accelerating AND when i take my foot off the gas while in gear itll sound 10x worse.
Im leaning towards the input shaft bearing, but I dont have the cash to fix it anytime soon. What I wanted to know was is there some additive like lucas or syncromesh or something that could ease the stress on the bearing till I can get it fixed? Any help would be appreciated greatly this is my DD and the last thing i need is for it to break.
Last edited by DeLSoLRo; May 31, 2011 at 11:21 PM. Reason: edited problem description
Old May 31, 2011 | 11:21 PM
DeLSoLRo's Avatar
Default Re: Need help with tranny noise?
Bump, anyone?
Old Jun 1, 2011 | 04:33 AM
cheggie's Avatar
It sound like an ISB. You really need to pull the transmission and check further. There's no fix in a can for this sort of thing. The Honda manual transmissions are not difficult to disassemble and fix. You'd be suprised. If you can do a clutch job, you can probably do the ISB replacement.
Old Jun 1, 2011 | 04:49 AM
94EG8's Avatar
Seagull Management
Sounds like the ISB. There's nothing you can do with it besides replace it, the bearing cage breaks, eventually the cage completely flys apart and the ***** hammer between the inner and outer bearing races. Usually they'll go a long time like that though, just sounds bad. I have seen one that ruined the input/mainshaft though, deep groove got cut into the mainshaft.
Old Jun 1, 2011 | 08:44 PM
DeLSoLRo's Avatar
Thanks for the reply's. I guess im gonna be stuck hearing this noise for a while. Just today i noticed it is also making noise with the clutch not being pressed on idle, but once i turned the car off and back on it went away
mychdb2gsr
Transmission & Drivetrain
Jun 7, 2011 04:15 AM
kevinf_69
20
Feb 18, 2009 11:44 AM
onefastrx7turbo
Oct 15, 2005 12:31 PM
CTL
13
Mar 18, 2004 09:49 PM
krazy
Sep 3, 2002 03:50 PM
