turbo wont spin at idle
Old Feb 16, 2009 | 04:38 PM
si_ridah's Avatar
New User
Default turbo wont spin at idle
b16a t3/t04e ceramic ball bearing turbonetics turbo. compression is good from the last time i checked it. no leaks (other than the return oil line). smokes at cold start then goes away. no loss of power. any ideas?
Old Feb 16, 2009 | 05:00 PM
Terrible One's Avatar
Default Re: turbo wont spin at idle
check your wastegate to see if there's exhaust gas coming out of it during idle
Old Feb 19, 2009 | 06:44 PM
si_ridah's Avatar
New User
i've checked it. no leaks.
Old Feb 19, 2009 | 06:47 PM
Karl Buchka's Avatar
Do you have any pics of your oil return?
Old Feb 19, 2009 | 06:49 PM
yoshi-ua's Avatar
if everything okay, and theres no loss of power, why does it matter?
Old Feb 19, 2009 | 07:09 PM
tegman23's Avatar
Is it when you first start the car up cold? Or after the oil is hot it doesnt spin?
Old Feb 20, 2009 | 07:13 AM
AbitAvenger's Avatar
some dont spin at idle but id figure a BB turbo would... weird...
are you running a restrictor? how old is it?
Old Feb 20, 2009 | 08:28 AM
jfoster's Avatar
Does it spin freely by hand? If you up the rpms a little does it start to spin?
There's not alot of exhaust pressure at idle, many turbos won't spin at idle.
Old Feb 20, 2009 | 09:07 AM
ONELIFEMOTORSPORTS's Avatar
i have a holset on mine and it spins fairly fast at idle to fast for me to touch it!!
Old Feb 20, 2009 | 09:30 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i wouldn't worry about it. my tubro doesnt spin at idle
Old Feb 20, 2009 | 09:57 AM
champLSinteg's Avatar
How big of a turbo is it? If its a 57 or 60trim size it should be spinning at idle specially if its ball bearing. If you can spin it by hand freely take the downpipe off to see if the exhaust wheel is also spinning. I've seen turbos break the shaft and so the compressor wheel does not spin anymore.
Old Feb 20, 2009 | 11:23 AM
tegman23's Avatar
My turbo doesnt spin at idle, unless I spin it with my hand then the exhuast will normally keep it going....All depends on oil pressure and turbo type I think
Old Feb 20, 2009 | 04:56 PM
archull's Avatar
damn, thats odd. that isn't a very large turbo so it should spin freely at idle. Mine is spinning like crazy at idle but I only have a GT3076 with a .82ar exhaust housing on a stock K20z1 motor & a peakboost kit.
Kid-jdm-teggy
Feb 27, 2014 06:46 AM
swapped95
Sep 17, 2006 12:34 AM
boosted-EG6
Nov 12, 2005 09:46 PM
hybridb18
Mar 31, 2005 07:02 AM
riceburnah
Sep 26, 2004 12:38 PM
