why does my compresser wheel stop when im at idle???
Old 11-10-2005, 11:16 PM
boosted-EG6's Avatar
Default why does my compresser wheel stop when im at idle???
he my turbo started leaking oil out of the compresser side and i could not figure what it was untill like a few min ago i go to look at the compresser side and the damn turbine is not spinning, but it move if i get it alittle bit of gas
guys any suggestions will work
Old 11-10-2005, 11:35 PM
whoneedzvtec's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (unleashedhonda)
**** man, i dont think that is any good. mine spins lik a champ @ idle. u could have messed up the bearings & shaft when it was leaking oil. i have never seen a turbo that did'nt spin @ idle. i would call the company that makes ur turbo and get an answer from them too.
Old 11-11-2005, 12:24 AM
Default Re: why does my compresser wheel stop when im at idle??? (whoneedzvtec)
yea i think im going to have to do that cause i cant ride with my stuff messed up but i have a hx35W turbo but it requires a different 5 bolt flange and a rebuild
Old 11-11-2005, 12:29 AM
flip1199's Avatar
alot of larger turbo's wont spin at idle. nothing is wrong with that.
Old 11-11-2005, 05:40 AM
mike1114's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (flip1199)
Ahhhh.....the weekly why doesn't my turbo spin at idle post......
I mean seriously...
Old 11-11-2005, 06:41 AM
yellowhonda88's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (mike1114)
yup, my T3/T04E .63 ar 60 trim doesn't spin at idle....on a B16
Old 11-11-2005, 06:51 AM
BoostedEG6's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (yellowhonda88)
thats normal for a large turbo........... get another user name... hahaha j/k
Old 11-11-2005, 08:40 AM
B18 CYA's Avatar
search is down
Old 11-11-2005, 09:05 AM
HiProfile's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (boosted-EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-EG6 &raquo;</TD></TR><TR><TD CLASS="quote">i have a hx35W turbo but it requires a different 5 bolt flange and a rebuild</TD></TR></TABLE>
Just unbolt the turbine housing from the center cartridge. Then get a smaller plate of steel, drill holes that line up to those on the turbine housing, then bolt it up. You then have a functional system, just without the exhaust moving past any vanes. Rebuild turbo at your leasure.
Old 11-11-2005, 12:09 PM
gdrum's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (HiProfile)
My t3 60-1 .82ar does not spin at idle either on my k-series. A local mechanic who is certified yada yada said it had to do with my oil feedline being to small (-3an). HAHA
Old 11-12-2005, 08:40 AM
EsQueue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Ahhhh.....the weekly why doesn't my turbo spin at idle post......
I mean seriously...
Why can't people make sure that search is working before being a smart-***
Old 11-12-2005, 12:04 PM
The Destroyer's Avatar
Default Re: why does my compresser wheel stop when im at idle??? (SeaQuake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake &raquo;</TD></TR><TR><TD CLASS="quote">
Why can't people make sure that search is working before being a smart-***?
If you search I bet you'll find your answer.
Old 11-12-2005, 09:46 PM
areyouasian's Avatar
b/c replying with "SEARCH" gives them an extra post count
si_ridah
02-20-2009 04:56 PM
vtec_killer_
03-18-2008 08:53 PM
DelSolMike
03-09-2007 08:30 AM
swapped95
09-17-2006 12:34 AM
hybridb18
03-31-2005 07:02 AM
Quick Reply: why does my compresser wheel stop when im at idle???
