identifying si tranny or z6 tranny
Old Feb 16, 2009 | 07:54 AM
'95hatchCivic's Avatar
Default identifying si tranny or z6 tranny
how can i identify a si or z6 tranny so i dont get screwed over by a bad seller
thanks
Old Feb 16, 2009 | 08:10 AM
raidacaipo's Avatar
Default Re: identifying si tranny or z6 tranny
B series and D series trannies are completely opposite of one another. The B series of course is larger.
Old Feb 16, 2009 | 08:11 AM
nah i mean what they call a si tranny for the sohc shortest gear ratio
Old Feb 16, 2009 | 08:12 AM
1kleenef's Avatar
a civic si 92-95 came with a z6 in it so therefore they are both one in the same transmission
Old Feb 16, 2009 | 08:14 AM
roycivic92's Avatar
threre the same except the final. cant tell them apart until you put it in
dreamer_lokdelsol's Avatar
do they fit the same motors ?
ok so how do i identify the z6 tranny and thanks for clearing that up^
Old Feb 16, 2009 | 08:16 AM
raidacaipo's Avatar
You mean d15b?? hrmm I think the d15b tranny says Y4E on it.. correct me if Im wrong this is the jdm model
Old Feb 16, 2009 | 08:19 AM
i just want the shortest gear ratio tranny available for sohc but not a jdm tranny
so z6 is the easiest to get
Old Feb 16, 2009 | 08:27 AM
roycivic92's Avatar
get it off a si. thats the most secure way. i have a si but its starting to grind.
Old Feb 16, 2009 | 08:47 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The 92-95 Si came with a Z6...
Any 92-00 D series trans will bolt onto and work with any 92-00 D series engine.
ANY.
The only difference between the 92-95 EX and Si trans (both come with z6es) is that the EX has a slightly higher 5th gear.
The shortest gear D series trans is pairing up the internals from a D16 DOHC from a 1st gen integra to the internals from a 92-95 Si, IIRC.
Old Feb 16, 2009 | 09:40 AM
doubleoazn03's Avatar
my tranny stock on my eg si says s20 on it.
Old Feb 16, 2009 | 01:09 PM
94EG8's Avatar
Seagull Management
Check the stamp in the transmission case. A000 Designates a small bearing case (CX/DX/LX/VX) and B000 designates a big bearing case (EX/Si/JDM D15B Vtec) The only caveat is that I believe the HX coupes also used a big bearing case. Below are pics of the identifying stamps.
A000 Small bearing case.
B000 Big bearing case.
Old Feb 16, 2009 | 03:02 PM
thanks guys for the info much appreciated
any info on your previous d series tranny/clutch/lightweight flywheel setups would be great the best performer for you set up
like i want to get the most power to the ground out of my single cam, with header full exhust bigger t/b cai and stock p28
i just want a fun d till i go B20vtec fully built
Old Feb 16, 2009 | 03:04 PM
roycivic92's Avatar
save ur money for the b20 vtec
Old Feb 17, 2009 | 09:06 AM
^haha true but that can be awile any body?
drewbie
May 23, 2006 05:41 AM
3RX
Northeast (Sales)
May 14, 2006 04:22 PM
no_one_
Nov 10, 2004 06:17 AM
SleepyHF
Mar 31, 2004 06:07 PM
boondockgtr
Oct 23, 2003 04:11 PM
