identifying si tranny or z6 tranny
how can i identify a si or z6 tranny so i dont get screwed over by a bad seller
thanks |
Re: identifying si tranny or z6 tranny
B series and D series trannies are completely opposite of one another. The B series of course is larger.
nah i mean what they call a si tranny for the sohc shortest gear ratio
a civic si 92-95 came with a z6 in it so therefore they are both one in the same transmission
threre the same except the final. cant tell them apart until you put it in
do they fit the same motors ?
ok so how do i identify the z6 tranny and thanks for clearing that up^
Originally Posted by '95hatchCivic
(Post 37428047)
i just want the shortest gear ratio tranny available for sohc but not a jdm tranny
so z6 is the easiest to get |
get it off a si. thats the most secure way. i have a si but its starting to grind.
The 92-95 Si came with a Z6...
Any 92-00 D series trans will bolt onto and work with any 92-00 D series engine. ANY. The only difference between the 92-95 EX and Si trans (both come with z6es) is that the EX has a slightly higher 5th gear. The shortest gear D series trans is pairing up the internals from a D16 DOHC from a 1st gen integra to the internals from a 92-95 Si, IIRC. |
my tranny stock on my eg si says s20 on it.
Check the stamp in the transmission case. A000 Designates a small bearing case (CX/DX/LX/VX) and B000 designates a big bearing case (EX/Si/JDM D15B Vtec) The only caveat is that I believe the HX coupes also used a big bearing case. Below are pics of the identifying stamps.
A000 Small bearing case. http://i234.photobucket.com/albums/e...F5016Large.jpg B000 Big bearing case. http://i234.photobucket.com/albums/e...F5024Large.jpg |
thanks guys for the info much appreciated
any info on your previous d series tranny/clutch/lightweight flywheel setups would be great the best performer for you set up like i want to get the most power to the ground out of my single cam, with header full exhust bigger t/b cai and stock p28 i just want a fun d till i go B20vtec fully built |
save ur money for the b20 vtec
^haha true but that can be awile any body?
