Auto to Stick (killswitch)
Okay well i got my car and it use to be auto but they last owner switch it to stick.
i can start my car without putting my foot in the clutch and i wanna run a kill switch to something but i cant run it cause of that problem is there a way to change that?
some1 told me there is a sensor in the pedal that fixes that problem
and im tried to search it but i cant find it
cmon honda-tech help me
lol so it is a sensor?
one of my boys said u have to take the whole clutch assembly out and put one from a manuel car then it should work
but i wanna know if thats the problem
on the auto shifter selector box there is wires and for the car to run you have to connect to wires together basicaly what you do when you press the clutch in remove your center consol and around you shifter look for 2 wires spliced together. when you find them cut them apart and instal switch
i just wanna know how do you change it so that i can press the clutch and my car will start
cause i can start my car with and without my foot on the clutch
some guy posted his convortion one day and just extended the 2 wires to the clutch pedal and hooked it up to one of the 2 sensors dont recall if it whish one it was
Maybe it's just me, but I always push in the clutch out of habit. I guess because those old FB Rx7's don't have a clutch switch.
Is it that bad? I hope you get it figured out, but this is definitely a step I will skip in my manual conversion.
I believe this is what you're looking for:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/5th-gen-civic-auto-manual-starting-circuit-right-way-2348557/
love_ek9's
Sep 3, 2009 07:58 AM
JDMvtecDRAGSTA
Mar 24, 2002 10:47 PM
