CEL code for 94 civic w/b16a
Old Feb 8, 2009 | 03:50 PM
Esfour's Avatar
Default CEL code for 94 civic w/b16a
I just pulled the codes and I got 22 and 23 which are vtec pressure valve and knock sensor. I just had the vtec solenoid sealed with hondabond and the screen cleaned and it the code popped up for vtec pressure. I checked the oil in the car and the level is fine I also checked both connections and they are fine. Any help would be much appreciated to fix both.
Thanks in advance,
Old Feb 10, 2009 | 06:07 PM
Esfour's Avatar
Default Re: CEL code for 94 civic w/b16a
I took apart the vtec solenoid and cleaned all the honda bond off and put new oem gaskets in. I still have the vtec pressure valve code popping up. Any input would be much appreciated.
Thanks,
Old Feb 10, 2009 | 06:11 PM
joshkx's Avatar
what type of harness do u have....
joshkx's Avatar
u might have to rewired...
Old Feb 10, 2009 | 06:38 PM
Esfour's Avatar
its obd1. The problem seemed to be start after trying to fix the leak in the solenoid. I am not 100% sure though.
Old Feb 11, 2009 | 04:32 PM
Esfour's Avatar
anyone?
Old Feb 15, 2009 | 09:45 PM
Esfour's Avatar
bump
Old Feb 16, 2009 | 01:57 AM
Inliner's Avatar
did you check all the wiring you were handling during installation nothing was nicked or cut?
Brandoff
Sep 1, 2008 03:15 PM
david22ky
Aug 14, 2007 01:30 PM
over_
Dec 2, 2006 03:55 PM
cates_07
Jun 7, 2006 12:22 PM
Fuster_Cluck
May 15, 2003 10:05 AM
