Valvetrain ?
Old Feb 5, 2009 | 10:41 AM
itgrowsind's Avatar
Default Valvetrain ?
I will be putting in some new CTR cams in my b16 should I upgrade anything and if yes what should I? maybe valves,springs,retainers.....what brand should I look into?? I do know that I am set with my rev limiter so not looking to rev any higher
My mods will be cf password intake,jdm4-1 header,s2 pro IM,p28/hondatas300...what else can I add to increase hp? besides exhaust
Old Feb 5, 2009 | 10:46 AM
Mashimaro's Avatar
Default Re: Valvetrain ?
you can either go aftermarket valvetrain (ie: Skunk2 stuff) or you can buy OEM ITR or CTR valvesprings, retainers, etc.
you could run your stock B16 valvesprings as well, but i wouldn't recommend it even though others have done it without destroying anything (so they say).
Old Feb 5, 2009 | 11:31 AM
HCivicSi23's Avatar
If your looking to save money and some spare time, personally I would just take the valve train apart and check all clearances/tolerances along with the condition of everything etc. If all makes out okay, just run the stock valve train components.
As far as aftermarket is concerned, just pick up a couple of adjustable cam gears. You will have to tune in order to ensure the b16b cams provide a positive gain (look at valve open/close events, overlap duration etc.) Good luck!
Old Feb 5, 2009 | 11:59 AM
93egSLEEPER's Avatar
stock valve train is fine. IMO it would be a waste to upgeade the springs and retainers for stock honda cams
Old Feb 5, 2009 | 12:44 PM
itgrowsind's Avatar
ok some argue yes and no to upgrade....If I decided too upgrade where can I purchase the ctr springs,retainers and valves Thanks for the info so far
Old Feb 6, 2009 | 05:31 AM
itgrowsind's Avatar
up.....
Old Feb 6, 2009 | 05:36 AM
xxstuntin4life's Avatar
i am personally running a b16a3 in my 93 coupe bone stock valve train/pistons etc... and i have a set of ITR cams in my car and it runs great.. its my daily driver and i smash on it a lot! im always sitting in vtec.. havent had a problem with it yet..
Old Feb 6, 2009 | 06:35 AM
Jimster480's Avatar
stock b16 valvetrain should be fine. The CTR cams arent really agressive anyway.
Old Feb 6, 2009 | 06:55 PM
testdriver91's Avatar
Supertech
lee0149
Nov 20, 2008 05:57 PM
silverintegra83
Jul 7, 2006 06:55 PM
LsVtecCoupe00
May 9, 2005 06:04 AM
caranjo
Jan 13, 2005 07:52 PM
-16V-
Nov 19, 2002 10:20 PM
