how high can i go?
Old Jul 5, 2006 | 02:58 AM
silverintegra83's Avatar
Default how high can i go?
right now stock b16a3 block turboed. ctr cams. stock valve train on 6psi. how high is the max i can rev to? how about on 10psi? and if i upgrade the valvetrain to ITR. what would be the max i can rev to then? im looking to do about 9k-10k rpms what would i need to do to get to this goal?
Old Jul 5, 2006 | 03:25 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: how high can i go? (silverintegra83)
i have been told that the itr valvetrain only works with itr valves or lighter valves. personally i am using REV valvetrain, and spinning to 9400 on shifts and 9000 through the traps.
Old Jul 5, 2006 | 05:24 AM
oscarmayer's Avatar
till it blows up.
every engine is differnet, and every setup is different.
Old Jul 5, 2006 | 09:26 AM
hotimportcrx's Avatar
Default Re: (oscarmayer)
i revved my stock b16 turbo to 9k like it was its job..but be careful if you drop a valve its over...i would defiently invest in some valvetrain its not to expensive and not to hard to install (just frustrating sometimes). Trying to rev past 9 or to 10k you will eventually drop a valve on stock valve train. What turbo are you running out of curiousity?
Old Jul 5, 2006 | 10:34 AM
Default Re: (hotimportcrx)
im running a t3/t4 turbo. so with stock valvetrain i can go to 9000 safely with the ctr cams? thax for the input guys.
Old Jul 5, 2006 | 10:41 AM
eg crunkmonster's Avatar
Default Re: (silverintegra83)
does the car even make power up that high? look at your dyno graphs and see if its still climbing. no point of over revving a motor if its not making power up that high and dropping a valve is a bitch, i know from experiance
Old Jul 6, 2006 | 12:18 AM
Default Re: (eg crunkmonster)
but if im boosting doesnt it keep gaining hp as i go higher?
Old Jul 6, 2006 | 08:13 AM
scB20teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverintegra83 &raquo;</TD></TR><TR><TD CLASS="quote">but if im boosting doesnt it keep gaining hp as i go higher?</TD></TR></TABLE>
No.
Old Jul 6, 2006 | 09:16 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (scB20teg)
Old Jul 6, 2006 | 10:49 AM
Default Re: (wantboost)
can you guys explain more then just a "no"?
thanx
Old Jul 6, 2006 | 10:52 AM
wantboost's Avatar
Who is Mr Robot?
its called a powercurve. its not a linear line, it rises then it falls.
Old Jul 6, 2006 | 11:06 AM
what parts are needed or what can i do to make the power curve keep rising until 9k?
Old Jul 6, 2006 | 11:12 AM
spooledex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverintegra83 &raquo;</TD></TR><TR><TD CLASS="quote">what parts are needed or what can i do to make the power curve keep rising until 9k?</TD></TR></TABLE>depends on a whole lot of things. Turbo and motor size. Even cars putting down 500 will lose power after like 7800 rpms. I wouldn't worry too much about how high you rev instead worry about numbers. A car that has a wider power band can beat most cars that make more hp.
Old Jul 6, 2006 | 11:17 AM
scB20teg's Avatar
Default Re: (spooledex)
Why do you feel the need to rev so high? Your CTR cams are a good start, you just need a big *** turbo and good tuning now, that should make power and hold to 9k.
Old Jul 7, 2006 | 06:55 PM
k, thanx for the replys guys.
SAMA_BINBOOSTIN
Jun 17, 2011 06:17 PM
BoiTypeR
Feb 6, 2010 09:15 AM
pwr2lbs
Jun 1, 2005 07:05 PM
allmotorek8
May 11, 2005 10:48 AM
ludesleep
Jun 12, 2003 06:25 AM
