Radius arm bolt installation
Old Aug 8, 2002 | 09:34 AM
zig's Avatar
zig
Default Radius arm bolt installation
I've got a 1990 Integra LS and I'm attempting to attach my radius arm to bracket behind the rotor. I can't get the mf'er aligned to put the two bolts in. I've tried jacking up the suspension to place it under load, and that gets it up high enough, but I can't get it aligned laterally (side-to-side). What's the trick? Thanks in advance.
Old Aug 8, 2002 | 09:50 AM
riceboy's Avatar
Default Re: Radius arm bolt installation (zig)
dont bolt it to the crossmember before the LCA
Old Aug 8, 2002 | 09:57 AM
zig's Avatar
zig
Default Re: Radius arm bolt installation (riceboy)
Well, I'm not installing a new radius arm, the bolts just fell out. Do I have to detach the front of it to get it aligned or is there another way? How hard is it to detach? Thanks.
Old Aug 8, 2002 | 10:04 AM
riceboy's Avatar
There is a 14 MM in the front cross member, you will need a deep socket for that one. Back that off. Take the two out on the LCA, pull the radius arm toward the firewall, and it will pull out of the front crossmember, make sure to pay attention to the positioning of the bushings that are where it connects to the front crossmember. when you reinstall, work in exactly reverse of the removal.
Old Aug 8, 2002 | 10:07 AM
zig's Avatar
zig
do I need to remove anything to the 14mm? I don't see it.
Old Aug 8, 2002 | 10:08 AM
zig's Avatar
zig
nevermind, found it, i'm blind. sucker's rusted to hell though :\ this is gonna be a bitch
Old Aug 8, 2002 | 10:47 AM
riceboy's Avatar
yea, thats why its a good idea to clean the suspension on a regular basis. Have fun
Old Aug 8, 2002 | 10:58 AM
zig's Avatar
zig
well, it's to be expected, car's got 160k mi. on it. just got my socket stuck on it :\ i'm at my wit's end
supaman
Suspension & Brakes
Aug 4, 2016 06:47 AM
cris17
Dec 30, 2013 06:18 AM
AllmotorGSReg
Suspension & Brakes
Apr 1, 2010 08:02 AM
civicdelsol33
Dec 11, 2007 09:20 PM
M@
May 17, 2005 04:35 PM
