Replacing bad Y8 with a Z6, keeping OBD2
Old Feb 3, 2009 | 07:07 PM
MinorObsession's Avatar
Icon6 Replacing bad Y8 with a Z6, keeping OBD2
Has anyone done this? Only replacement motor I could find that was single cam VTEC, is a Z6 motor. I have the Y8 out, took of intake mani, dist, etc...... The thing that is throwing me is the crank sensor. Has anyone else done this without rewiring the car, can I flush out the old oil pump and bolt it on the Z6 motor? Thus giving me the mounting location for the sensor. HAVE to make this work.
Old Feb 4, 2009 | 04:00 AM
94EG8's Avatar
Seagull Management
Default Re: Replacing bad Y8 with a Z6, keeping OBD2
Its been done before. As far as the CKF sensor goes simply perform the CKF fix as seen here ---> http://technet.ff-squad.com/ckftrick.htm
You will also need to build a custom distributor, use the Z6 distributor case and the shaft/bearing plate assembly with the Y8 sensors.
Old Feb 4, 2009 | 05:19 AM
THANK YOU 94EG8 this rocks, exactly what I was looking for.
Old Feb 4, 2009 | 06:51 AM
94EG8's Avatar
Seagull Management
Forgot to add:
Timing will be somewhat off with the OBD2 ECU (I don't know just how far off)
You wont pass emissions in some states
Old Feb 4, 2009 | 09:54 AM
no emissions in michigan, so far. thanks
Old Feb 4, 2009 | 01:17 PM
Everything is ok, but what do you do about the knock sensor? none present on the Z6 block? Will this throw a cel?
Old Feb 4, 2009 | 02:17 PM
94EG8's Avatar
Seagull Management
You should be able to drill and tap a hole for knock sensor, the Z6 doesn't have one, and yes it will throw a CEL.
FSTSOHC
Oct 11, 2011 05:40 AM
bigpwr
Jun 19, 2010 11:20 PM
Budd9880
Aug 23, 2009 01:04 PM
sdj02
Aug 21, 2008 03:02 AM
chue_li
10
Mar 14, 2005 02:45 PM
