Advancing timing???
Old Aug 8, 2002 | 08:29 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Advancing timing???
I was just wondering how this is done...ive herd of doing it but i dont know how to. And is it safe...im running righ right now so it might actually help me out...lol. Thanks guys.
Sean
Old Aug 8, 2002 | 08:36 AM
4gvtec's Avatar
Default Re: Advancing timing??? (sCeRaXn)
you have a adjustable cam gear?
Old Aug 8, 2002 | 08:52 AM
dohcsideSi's Avatar
with the distributor?? just to let you know there is a thing as too much advance..
Old Aug 8, 2002 | 09:07 AM
sCeRaXn's Avatar
Default Re: Advancing timing??? (dohcsideSi)
Yea...im talking about with the distributor. And how do you advance it period. And since you can do it too much how do you know if its a good setting? I guess you just have to play with it? Thanks guys.
Sean
[Modified by sCeRaXn, 6:08 PM 8/8/2002]
Old Aug 8, 2002 | 09:25 AM
Urban Business
Guest
Posts: n/a
buy a timing light
Old Aug 8, 2002 | 09:43 AM
civicmark's Avatar
Default Re: Advancing timing??? (TorteX)
buy a timing light
Old Aug 8, 2002 | 01:47 PM
sCeRaXn's Avatar
Default Re: Advancing timing??? (civicmark)
What is a timing light and where can i get one. Oh yea....how much is it? Thanks.
Sean
Old Aug 8, 2002 | 01:53 PM
pelotudo's Avatar
Discount Auto Parts, Autozone, Pep Boys, Napa...anywhere should have them. You can probably get one for about $20-$30.
Try this: Retard it all the way (Pully dizzy toward you). Move it up LITTLE BY LITTLE, blipping the throttle (on the intake manifold, pull up a little bit on the throttle cable). You will notice that when it's all the way retarted that it will bog a little bit, and then jump up in RPM's. Keep doing this until it feels 'good'. Good would be that when you blip the throttle, the response is quick, but not instantaneous. I would suggest that if you have never done it before to get the light, but doing it by hand can be done. Just make sure you don't advance it all the way...and if you do advance it too far, you will hear a knocking sound when on the accelerator... If you hear this...stop, and retard it back down a little. That's detonation from being too far advanced, and is a really good way to blow your engine.
jB
Old Aug 8, 2002 | 04:12 PM
dpo95si's Avatar
Default Re: Advancing timing??? (PeloTudo)
got a stock sohc zc. (internals are stock) what is the best degrees to set an aem cam gear? i've only got a header(to rusty, not sure what brand) ebay intake and a apexi world sport exhaust.
Old Aug 8, 2002 | 04:37 PM
vulcandan's Avatar
Default Re: Advancing timing??? (dpo95si)
When you go to adjust your timing, Mr. S, make sure you having "jumped" the ecu connector by the kick panel on the passenger side. Because you are adjusting the timing at idle speed, you need to jump that connector so the ecu doesn't adjust the timing at all. That connector on my ef is blue with two pins, just so you know.
[Modified by vulcandan, 1:39 AM 8/9/2002]
andyvaj
May 7, 2007 07:34 AM
adip315
Jan 28, 2007 04:48 AM
92EG8
Nov 21, 2006 09:01 AM
johnbrooke86
Aug 23, 2004 04:49 PM
turbo Si
May 7, 2002 12:59 PM
