Help D16Y8 B7 Distributor Ignition Timing how?
I need to know how to do my timing on a B7 distributor on Y8 Motor. I need a step by step on doing the Distributor Timing and not the cam timing. All help is appreciated .
Re: Help D16Y8 B7 Distributor Ignition Timing how? (92EG8)
What do you mean? With a timing light or the firing order? If you have a timing light just break the bolts loose and rotate the dist til you get it to where you want it.
Firing order, is:
1342
34
12
The flat top is 34 then 12 under. So itll be tilted.
Firing order, is:
1342
34
12
I meant to do the timing So i need a timing light? Also thanks for the firing order needed that too. Then what do i do after i aquire a timing light
ek_James
08-31-2007 12:35 PM
andyvaj
05-07-2007 07:34 AM
HTn00b
03-10-2007 10:17 AM
