Clanging in motor?
Old Feb 1, 2009 | 10:37 AM
InTheLBC20's Avatar
Default Clanging in motor?
When its cold and i first start my car, my engine makes this horrible rattling sound but when it warms up after about 15 mins it goes away. It sounds like its coming from around the oil pump/water pump area. I have no idea what this noise is and I want to fix it. Anybody ever had this problem before? Its a B18B1 btw
Old Feb 1, 2009 | 12:01 PM
sp00nek9's Avatar
Default Re: Clanging in motor?
i have a similer noise/issue on my ls vtec. i was thinking its a bad bearing in the timing belt tensioner
Old Feb 1, 2009 | 01:01 PM
Redbone's Avatar
how long has it been since you did timing belt, water pump and tensioner replacement? If its been a LONG time you might want to think about doing that very soon.
Old Feb 1, 2009 | 04:34 PM
InTheLBC20's Avatar
its been awhile. The car the motor came out of sat in a field for like 5 years without being driven, then the guy towed it to the junkyard and thats when i got the motor. Im suprised the timing belt hasnt snapped yet! Im going to change the timing belt, water pump, tensioner, and head gasket next weekend.
Old Feb 1, 2009 | 05:11 PM
Redbone's Avatar
holy **** and u just picked it up and drove it after that? dude you better change that stuff out QUICK!
Old Feb 1, 2009 | 07:07 PM
looseOFFboost's Avatar
yeah I would change that stuff. But THose things really dont expand. I would check for piston slap. Before I spent the money and time. How many miles is on the engine? Just my opinion.
Old Feb 2, 2009 | 11:17 AM
InTheLBC20's Avatar
like 175,000ish. i think it might be my rear mount clanging
Old Feb 4, 2009 | 07:20 PM
InTheLBC20's Avatar
my rear motor mount was clanging. the top bolt was a little lose...but i deffinately need a tensioner cause nows its jingling and rattling and all kinds of ****. It sounds 10 times worse now since i decribed it in my first post. My buddies got a spare tensioner in his garage im gonna replace it tomorrow along with a new timing belt ill report the results when i finish.
Old Feb 5, 2009 | 03:48 PM
Redbone's Avatar
make sure you do the water pump while you're in there at least i hope you did.
Old Feb 5, 2009 | 05:33 PM
darkblackH2B's Avatar
Could be valve tap as well. Maybe look into getting your valves adjusted.
B18C1NMotion
Nov 20, 2007 11:27 AM
ebonyrolla7
Oct 27, 2005 09:05 AM
civic_tuned
23
Jul 26, 2005 08:42 AM
0 0 0
May 31, 2003 05:28 AM
