3 bar map or missing link????
Old Jan 30, 2009 | 02:18 PM
jdmdikk's Avatar
Default 3 bar map or missing link????
ls vtec turbo build and i just want to kno if i can use my missing link for my setup or would i have to get a 3 bar map?
i will get injectors,fuel pump ,fuel pressure regulator and chipped ecu..so my questions is>>can i use my missing link to combine with these things and tune or would i require a map sensor???
Old Jan 30, 2009 | 02:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 3 bar map or missing link????
if you are asking this question, you have a little learning to do.
but to asnwer, if you are getting a chipped ecu, you dont need the missing link. and if you plan on using the boost cut feature correctly, the 3 bar will facilitate that a little better. the stock map can only read to 11.2 psi, the 3 bar will allow you to go to 11 psi and still use a boost cut.
Old Jan 31, 2009 | 01:27 PM
jdmdikk's Avatar
well actually i kno that the 3 bar holds way more then 11psi..its like 20+ .
Old Jan 31, 2009 | 01:33 PM
jdmdikk's Avatar
Key Features:
GM 3 Bar to allow up to 29 psi of boost
Pressure tested to over 130 psi without leaking
-40 to 260 degrees Fahrenheit optimal temperature operating range
Able to respond from 10% of the pressure scale to 90% of the pressure scale in .001 seconds (the fastest response time of any MAP sensor on the market) which translates into improved boost response.
my question was that if i have a missing link ,could i use that with a tune or would i have to get a 3 bar map..simple question doesnt require a stupid answer.
Old Jan 31, 2009 | 01:44 PM
JtriX21's Avatar
What are you gonna run for boost?!
Old Jan 31, 2009 | 02:00 PM
trustdestruction's Avatar
Don't use a missing link. All that does it trick the ECU. Get a higher bar MAP sensor so your ECU knows what is actually going on.
Old Jan 31, 2009 | 02:05 PM
jdmdikk's Avatar
ok ill .just sell the stupid missing link and get a 3 bar
ganjasnack
Apr 18, 2008 06:08 AM
QwkD16
Jan 5, 2006 07:39 PM
B18Sleeper
Oct 26, 2005 12:52 PM
redlseg
May 11, 2005 06:48 AM
dc r-spec
Jun 4, 2002 11:36 PM
