Ex/Si cluster in CX not working..
Old Jan 30, 2009 | 07:08 AM
darkblackH2B's Avatar
Default Ex/Si cluster in CX not working..
Hey guys i just put a new Ex/ Si gauge cluster in my 92 cx because i wanted a tach. The tach doesnt seem to be working though. the cluster is brand new, is there something i need to wire up to get the tach working on this? I was thinking they were plug and play. thanks for any help guys.
Old Jan 30, 2009 | 08:35 AM
DAP97SI's Avatar
Default Re: Ex/Si cluster in CX not working..
double check that all the plugs are connected.
Old Jan 30, 2009 | 08:36 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Check that the plugs are in the right places and that the tach wire from your distributor is good.
Old Jan 30, 2009 | 08:39 AM
The plugs are all snug my man ive taken it out and put it back in a few times now and still nothing. everything on it works except the tach. anyone else?
Old Jan 30, 2009 | 08:42 AM
What color is the tach wire from the dizzy gonna be havent checked that!
Old Jan 30, 2009 | 08:43 AM
B serious's Avatar
IIRC, it's blue. There should be a junction by the drivers side shock tower for it. It should be a single blue wire with a black cap on it.
Old Jan 30, 2009 | 09:05 AM
I just went and found the wire. It was capped off and just sticking out of the rest of the wiring harness. Im guessing that wire needs to be going somewhere...? Thanks so far guys! what now!
Old Jan 30, 2009 | 09:29 AM
94EG8's Avatar
Seagull Management
That is the tach test wire, its there for a tech to plug in an external tach for diagnostic work. Check the distributor, make sure it has a blue wire coming from it. The EX/Si cluster is 100% plug and play, there is no wiring you need to do, i've installed several of them in numerous civics.
Old Jan 31, 2009 | 10:39 AM
Yes there is a blue wire coming from the distributor. All the wires are taped up so what do i need to do trace that wire all the way to the cluster? Anyone with any other ideas? Ive put in clusters in before never dealt with this before, it must be something deeper than just plugging it in.
Old Jan 31, 2009 | 10:45 AM
EGIan's Avatar
I've done exactly that yesterday but the RPM gauge might be a little problematic (not working, lag, etc.). As mentioned above it's 100% plug-and-play.
Was the hardware completely legit before being transplanted into your car ? I mean was it working correctly before ?
BTW : I've seen a lot of people opening their clusters up to put some fancy gauges and all, messed with the needles a little bit, and it broke. It could simply electrical.
Old Jan 31, 2009 | 04:48 PM
yeah it was a new, un-messed with cluster..bump
Old Feb 1, 2009 | 07:01 AM
any other ways i can get this hooked up guys?
Old Feb 1, 2009 | 08:41 PM
Old Feb 2, 2009 | 06:00 PM
ttt
Old Feb 3, 2009 | 03:31 AM
NVturbo's Avatar
O.G. triple O.G.
More than likely the previous owner tried to install an aftermarket tach and he/she wired up straight to the blue wire at the distributor. Just find the other end of the cut wire and re-solder it together and the tach on the gauge cluster should work.
89dohcEF
Sep 7, 2005 10:44 PM
918-Hatch
Nov 27, 2004 03:27 AM
egreenmachine
13
Aug 17, 2004 02:04 PM
joecivic93
Jan 6, 2004 10:07 PM
B19CivicHB
Oct 31, 2001 09:53 AM
