have you borred out your A6?
Most I've seen is 1mm OS on stock sleeves(76mm), and around 78 or 79mm with a resleeve. 1.8l is only possible with a D17 crankshaft/stroker.
It's very helpful because overboring not only increases displacement slightly, but also helps to deshroud the valves.
Humble Performance hit around 163whp/140ft-lb tq on a 78mm bore D16(using stock P08 head). Only mods were I/H/E(Bisimoto header) and Hondata S300.
There's quite a few people that mod D-series; it's just not popular on H-T.
It's very helpful because overboring not only increases displacement slightly, but also helps to deshroud the valves. Humble Performance hit around 160whp IIRC on a 78mm bore D16(using stock P08 head). Only mods were I/H/E(Bisimoto header) and Hondata S300.
That's not my engine, and no, it's not boosted.
1mm OS= 1mm Oversize(going from 75mm bore to a 76mm bore). to figure out the displacement, you'll have to do some math:
what I do is convert everything to cm, makes it easier;
pi*(Bore/2)^2*Stroke*number of cylinders=displacement.
For instance, a 78mm bore D16:
pi*(7.8/2)^2*9*4=1720cc(or 1.7l). For reference, stock displacement is 1590cc(about 1.6l)
well obviously they weren't trying to make power by doing that.. they were most likely tryin to clean up deep gouges in the cylinder wall, and without a slight overbore the rings wouldn't have seated in properly.
well my friend has a zc that is bored .5 over
that makes it 75.5mm bore
im pretty sure we figured out all that math and concluded it gained .1 litre
so .5mm over stock bore would potentially net you a 1.61L or roughly 1610ccs
It's not recommended to go larger than a 78mm bore on a sleeved block. It's the equivalent of trying to do an 87mm bore bseries. Its do-able but wont last long
i got a friend thats using stock components with bolts ons and is making 162whp. this is a d16z6 block, dohc zc pistons on stock rods, d16a6 head, intake/header/exhaust, and adjustable cam gear. he uses hondata s300, and had it professionally tuned.
SpoonfedCivic
Aug 13, 2014 08:47 PM
EFnSPOOLIN
26
Jul 14, 2008 07:47 AM
