What is a wastegate??
Old Aug 7, 2002 | 02:39 PM
Downey's Avatar
Default What is a wastegate??
Sorry, im not to educated in turbos, just wanted to know what a wastegate is, and does? My friend said his "external wastegate" is illegal. Why? thanks guys
Old Aug 7, 2002 | 02:42 PM
Spade's Avatar
Default Re: What is a wastegate?? (Downeybear11)
His is SMOG illegal....it vents built up pressure to maintain a specific amount of boost....
Old Aug 7, 2002 | 02:43 PM
hondafrk's Avatar
a wastegate is simply the little thingy that limits your boost. I dont really know why any wastegate would be illegal. When your turbo spools up it can turn out a very high amount of air at a very high pressure, A wastegate is used to basically bypass some of the air at a preset psi. Example: If you have your car running on 7 psi of boost. When the wastgate senses 7psi, it opens and bypasses all pressure except for 7psi, If you are running 12psi of boost, Same principle. I dont have a turbo or really know much about them but I think that they are pretty self explanatory.
Old Aug 7, 2002 | 04:07 PM
Mike P.'s Avatar
25 Year Member
Default Re: What is a wastegate?? (hondafrk)
You're close, except that it's not air that it's venting. It's raw exhaust gas. That's why an external vent is illegal. Exhaust gases run the turbine.
Old Aug 7, 2002 | 04:12 PM
Downey's Avatar
Thanks for the explanation guys!
Aero91
May 11, 2009 01:43 AM
kamAccord
Jan 7, 2005 08:28 AM
toxicshit
Aug 15, 2004 12:14 PM
technine
Feb 27, 2003 11:50 AM
B20-T
Aug 3, 2002 04:31 PM
