Mini- me Build ?'s
Old Jan 27, 2009 | 12:36 PM
popndrop's Avatar
Default Mini- me Build ?'s
ya i have read other write ups but not sure if im stupid but i cant get the answers im looking for
Here's what im doing
Z6 head and intake Manifold on a D15b7 block
Heres my questions
1.Which head gasket do i use
2. Do i have to run an external Vtec oil line
3. Which Timing belt do i use
4. Which Dizzy ?
5. i have P28 ecu and Vtec subharness
Anything else i need??
Old Jan 27, 2009 | 12:51 PM
j0keefe21's Avatar
Default Re: Mini- me Build ?'s
heres what i can tell you... you can use the z6 head gasket or the y8. i've heard the y8 is beater and cheaper so thats what one i would use. also you can take out the middle layer of the y8 gasket to boost the CR. i dont believe you have to run an external vtec oil line. (someone correct me if im wrong!) just make sure to pull the oil plug between the second and third cylinder. it used to be said that you needed the timing belt off of a vx(103 teeth). but the one off the z6(104 teeth) fits much better. you need the dizzy and plug wires off of the z6. pop in the ecu and wire in vtec and you should be set.
Old Jan 27, 2009 | 01:16 PM
popndrop's Avatar
K so ...
Z6 Timing belt
Y8 head gasket
and no need for external Vtec line
and i did find out i need to pull the oil plug out thanks for reminding me though
Old Jan 27, 2009 | 02:16 PM
krysted9354's Avatar
and use the timing belt thats the same as head, our shop uses z6 head for mini me, THERE BUILT BETTER, and u can port it, get a metal y8 head gasket take out middle layer, also use a d15z1 or a d16z6 distributor, run a rpm activated switch for your vtec,
or vtec controller and tune it by a vtec light, other then that like said screw a screw into the oil pin in between 2,3 cylinder will come out with easy, and when using the d16z6 IM also use z6 fuel rail. good luck
Old Jan 27, 2009 | 02:28 PM
popndrop's Avatar
k so absolutely no need for an External Vtec line ???
so here is what im gonna do
Z6 dizzy
Z6 mani
Z6 head + valve cover etc
Z6 Timing Belt
Y8 Headgasket
on my D15B7 non vtec block
also wire Vtec and install my P28
Anything else ??
Should i be good to go here
Old Jan 27, 2009 | 05:48 PM
popndrop's Avatar
Ok i went out tonight and grabbed my Z6 head out of the garage i dont have the Cam gear on it does it matter if i take the B7 one off and us that ?? ive read its possible as long as i use the B7 timing belt is this true or would i wanna make sure i have the Z6 one on there
Old Jan 27, 2009 | 06:29 PM
powersk8er92's Avatar
I have a 94 Civic DX 4DR with no RPM gauge. haha.
I can run a wire for the gauge from my new P08 ECU right? Also is there a guide to setting up a RPM activated VTEC switch? or installing a VTEC controller? I'm doing the mini-me with a D15b JDM VTEC head.
Old Jan 27, 2009 | 06:47 PM
popndrop's Avatar
WOW hello thread jack !!!!!!
Old Jan 27, 2009 | 06:53 PM
popndrop's Avatar
Anyways my question is can i use my D15b7 Cam gear on my D16Z6 head w/ a D15b7 timing belt ??
Old Jan 27, 2009 | 07:39 PM
iamthefollower's Avatar
hmm, i'll check and see if the teeth are the same on the b7 cam gear and the z6 cam gear... I think they are the same, just the water pump and such is different which causes for the new timing belt..
Old Jan 27, 2009 | 07:50 PM
popndrop's Avatar
is this true ???
a6 b2 b7 z6 cam gear are all the same
also do i still use the z6 timing belt ??
Old Jan 27, 2009 | 07:58 PM
popndrop's Avatar
according to skunk 2 cam gears z6 and b7 are the same so do i stick with the z6 timing belt ??
Old Jan 27, 2009 | 08:26 PM
My bad. I get excited.
Old Jan 27, 2009 | 08:31 PM
popndrop's Avatar
Wow i so answered my own question if the cam gear is the same it wouldnt change the fact to use a z6 timing belt hahaha yea im an official idot !!!!!!!!!! go me !!!!!!!!
Joey Mitchell
13
Apr 6, 2019 09:05 PM
dohc4life
Aug 14, 2010 08:50 AM
buddy4002
Nov 10, 2006 12:54 PM
MrPotatoeHead
Jan 16, 2005 10:35 AM
rice a roni
Oct 8, 2004 08:39 AM
