SIR fog lights? wiring
Old Jan 23, 2009 | 01:37 PM
JdmB18C667's Avatar
Default SIR fog lights? wiring
has anyone ever wired a set up with the OEM switch and harness
I have everything but the wires between the harness with the switch and relay and the fog lights
Old Jan 23, 2009 | 07:25 PM
BlueIntegraBoy's Avatar
Default Re: SIR fog lights? wiring
So, you are missing the wire running from the switch harness to the fog harness? You can run a single 18G wire through the firewall to connect the two harnesses. This is what I did in my 92 hatch, since there wasn't one from the factory. I crimped on female-side spade connectors on the ends which plugged into the harness connectors.
Old Jan 23, 2009 | 08:13 PM
JdmB18C667's Avatar
I know where to plug everything in to the harness at but then what? i mean what do i have to splice after that and what one
Old Jan 24, 2009 | 09:37 AM
JdmB18C667's Avatar
anyone?
cstone
Lighting
Sep 30, 2009 02:36 PM
flyingduck04
27
Dec 30, 2006 03:52 PM
Matty.
14
Jan 2, 2006 03:49 PM
hYbRiD EeEkAy
Feb 2, 2004 04:29 AM
