89 Honda CRX - BOV doesn't work?!?
Old Jan 21, 2009 | 11:41 PM
ShayMK's Avatar
Default 89 Honda CRX - BOV doesn't work?!?
Hey, I have a 89 honda crx with a td04h turbo. I got my BOV in today, it's an exact look alike of the GReddy Type S BOV. I hooked it all up and I believe I ran the correct hoses everywhere and whenever I shift now all I still here is turbo surge...any ideas?
Old Jan 21, 2009 | 11:49 PM
ShayMK's Avatar
Default Re: 89 Honda CRX - BOV doesn't work?!?
I've also tweaked the screw on the top a bit also to see if that was the issue, but still nothing. I turned it to soft, nothing, turned it a bit more, nothing, then turned it to hard, and the same thing...nothing! I'm really hoping someone can help me out here.
Old Jan 22, 2009 | 01:11 AM
D16SiHatch's Avatar
so you had a bov before yes? if all you did was swap one out for another their's no reason why it shouldn't work. i do know if you don't run the vaccum for the bov directly off of the intake manifold you may encounter surging problems. as in the vaccum for the bov should not be T'd into another vaccum line going to something else if at all possible. it is also possible i suppose that the knockoff bov was doa on arrival and no tweaking is going to fix that.
Old Jan 22, 2009 | 03:17 AM
digitally_remastered's Avatar
pics of your vacuum wires and where they are running to. pics are worth a thousand words!!!
Old Jan 22, 2009 | 05:36 AM
Turbo Dan's Avatar
what psi does the gauge show the turbo spools to?
what vacuum does the gauge show the engine provides under decel?
make sure the vacuum line is between the throttle body and the head.
Old Jan 22, 2009 | 06:34 AM
dapek's Avatar
There is also a very large chance that you purchased a faulty egay bov which ocurrs all the time..IMO grab the real deal products that have been proven and tested
Old Jan 22, 2009 | 10:44 AM
ryan89crx's Avatar
open the bov and remove the large spring. leave the small one in it.
Old Jan 22, 2009 | 01:59 PM
ShayMK's Avatar
I think I might know my problem, other than it being from ebay lol...I t'd into something for the vaccum line to the bov... I will post pics asap
Old Jan 22, 2009 | 02:02 PM
ShayMK's Avatar
and aslo, the boost I am hitting is 5 psi and the vaccum is at 10 like it always has been
Old Jan 22, 2009 | 02:17 PM
ShayMK's Avatar
okay, so the first picture is showing where i t'd the vaccum line into...it's the dark blue hose. the second one is showing the back of the BOV, i was told that the top one was for vaccum and the bottom one was for pressure, and someone also told me to 'T' into the wastegate line for the pressure one. And whoever asked if I was replacing my other BOV, no. This is my first BOV.
Old Jan 22, 2009 | 04:40 PM
90crxdriver's Avatar
easy solution take it off and throw it away.
My intercooler kit came with that POS and it wouldn't work even after removing one of the springs. I bought the really deal and it works great.
Old Jan 23, 2009 | 12:10 AM
ShayMK's Avatar
I got it to work, I took it apart and took out the big spring, thanks for all your help guys
Old Jan 23, 2009 | 04:04 PM
ryan89crx's Avatar
good deal!
k20powered
May 10, 2010 11:37 AM
Slowass2dr
Mar 22, 2007 05:32 PM
RACEPAK
May 19, 2005 11:58 AM
iwhichisme
Jun 14, 2004 08:05 PM
wickedxboi
May 21, 2003 08:33 PM
