Do i have a P28?
Old Jan 11, 2009 | 10:34 AM
06turbocivic18's Avatar
Icon6 Do i have a P28?
I just bought a ecu from someone with a hondata unit. The ecu i bought the guy said came from a stock 93 si. The bar code was scratched off in the middle. The only numbers i have are 37820- then rest is scratched off. The bottom line says 740-512 and has in big letters APX. Is there any way to look inside ecu to see diagram to see if this is a manual P28?
thanks...
Old Jan 11, 2009 | 10:38 AM
95BoostedEJ1's Avatar
Default Re: Do i have a P28?
u can search on google for ecu bar codes..theres acouple pictures people will take to let u match up
Old Jan 11, 2009 | 05:52 PM
sql_civic's Avatar
Open the cover and look for another sticker with the part number near the connector.
Old Jan 11, 2009 | 06:15 PM
NVturbo's Avatar
O.G. triple O.G.
Why would a so-called Hondata dealer scratch out the Honda P/N on the ecu? That doesn't sound right.
Old Jan 11, 2009 | 06:23 PM
BryanM.'s Avatar
Resident Gearhead
No it doesn't sound right.
93-95 Sis do have P28 ECUs.
Old Jan 11, 2009 | 07:37 PM
DaveSi677's Avatar
you mean 92-95 have P28 ecus
Old Jan 12, 2009 | 01:45 PM
no. Im sorry i thought i had said that. I bought the hondata s200 unit off someone. and he sold the ecu with it. said was from a 93 civic si. I just wanted to make sure.. i will check the inside thanks..
Old Jan 12, 2009 | 01:46 PM
thanks sql civic... ill check
Old Jan 13, 2009 | 01:18 PM
ok thanks i found the other barcode the first line says 37820-P06-A00 the second line says 740-512933 3A06 .. Does this mean i have a P06? How can i tell if its manual or not? I was reading you can make the P06 a P28? Anyone help with that? thanks.
Old Jan 13, 2009 | 02:44 PM
sicones's Avatar
The guy scratched off the number because he is a D-bag and he was trying to hide the fact that it’s not a "real" P28, but it doesn’t matter. If it really has Hondata then it is most likely already manual and converted to VTEC, which is now just about identical to a P28.
Old Jan 13, 2009 | 04:30 PM
Jim Truett's Avatar
Take a decent resolution picture of the board and post it here. PM me when done, and I'll tell you what you have.
Old Jan 14, 2009 | 07:49 PM
k ill get pics up tomorrow. If i get the ecu chipped when i get my car tuned can they put in the chip so that vtec will work? Or would i have to convert the ecu still?
Old Jan 14, 2009 | 07:50 PM
i have the s200 unit and the ecu was not chipped.
shadhman
Engine Management and Tuning
13
Apr 17, 2009 12:55 PM
gloryhog
Sep 3, 2004 07:19 PM
DevineCRX
Oct 10, 2003 08:36 AM
92gs-r
Jul 11, 2002 11:01 AM
