help: b16 bugging out
sup guys just wanted to know if anybody know how i can solve this problem, my car runs fine on idle but when you drive for a few mints it bugsout RMP goes down. car wont move.
i change spark plugs, but i havent check the distributer yet.
thats exactly whats happening to mine. i swapped a b16 into a 96 ex and thats what happens too. i was thinking that it might be the fuel pump but im not sure. really hope someone knows what it is.
Need more info? Any Check engine lights? Kinda sounds like a fuel pump to me. Your getting spark evidently, so how long afterwards can you drive it or is it a crank right back up thing.
ill update you guys soon, hope i get my baby running soon....
yo man, take the dizzy cap off and clean the **** out of it. make sure your rotor looks nice and clean with a good connector and the 4 prongs inside the cap are nice and clean, file them down or something to make a cleaner connection. retard your timing a tiny bit(like 2mm) and reset your ecu.
thats all i did and it went away
What I would do if it was me I would make sure you have good plugs and wires. my recommendation would be ngk oem spec plugs and ngk blue wires and I would also replace the distributor cap, rotor button, and the coil in the distributor. just my .02 hope it helps sir.
yeah when its died the first time the code came up was too rich on fuel.(p0172) but, i took care of that,then its was running fine tell i was driving for around 20 mins around the block then its start bugging out again and it died. but few hours later start back up. a friend of mine came over so we can take a look at it he was telling me that it happend to him too it was his distributor so, now trying to findout where can i check my coil that might be the problem. i have a fully built head and i dont think my stock B16 distributor can poduce enough spark. he suggested to get a GSR distributor...
You could try switching out your distributer for a known working one (to see if there is a defect with your current one), but this: "i have a fully built head and i dont think my stock B16 distributor can poduce enough spark. he suggested to get a GSR distributor..." is not only wrong, but it is ridiculous.
bboyjimpy
62
Oct 7, 2012 03:38 PM
