Idle issue after cleaning manifold with mass air flow sensor a
Old Jan 6, 2009 | 05:42 PM
acmoc's Avatar
Default Idle issue after cleaning manifold with mass air flow sensor a
Hey,
I just tried this,
I went out looking for throttle body cleaner to spray into my manifold to clean it.
I saw they had a caution label that read not safe for sensors.
so I bought mass air flow sensor cleaner instead since it had the same ingredients just safe for sensors.
so I spray the whole bottle in their, throttle body and all.
I let it sit 10 minutes, then go to start it, it won't start, so I wait another five minutes.
finally it starts, and is running real good.
I go for a ride and I see at a stop my idle is jumping from 1200 to 800
My idle was fine before this.
Is this normal?
Do I have to let it lean out or something?
Thanks.
Old Jan 6, 2009 | 05:55 PM
D16SiHatch's Avatar
Default Re: Idle issue after cleaning manifold with mass air flow sensor a
either you've got a vaccum leak, or possibly spraying all that cleaner in there has clogged up your iacv. assuming you don't find an air leak first, pull the iacv off the back of the intake manifold and spray it out with brake parts cleaner. then shake all the cleaner out and let it dry for a bit before reinstalling.
Old Jan 6, 2009 | 06:10 PM
acmoc's Avatar
iacv? I hope that's the only thing that could be bad.
You don't think that stuff can get into other places and mess them up?
Like the brake booster?
Old Jan 6, 2009 | 06:17 PM
D16SiHatch's Avatar
nope. all air lines attached to the intake manifold are vaccum lines, and so is the big line to the brake booster. so anything sprayed into the intake manifold is being pulled away from everything else.
Old Jan 6, 2009 | 06:27 PM
acmoc's Avatar
ahh OK
I will see how it runs tomorrow, and clean the iacv if it needs it.
It's only two bolts and a hose.
But does anyone have a writeup?
Old Jan 6, 2009 | 06:38 PM
acmoc's Avatar
That stuff clogs? The label said it evaporates.
Maybe one whole bottle was too much
Oh, ;et me describe my idle
It stays at 1200 for a while then goes down
Old Jan 7, 2009 | 07:45 AM
acmoc's Avatar
so it has to be the iacv then?
Old Jan 7, 2009 | 12:46 PM
D16SiHatch's Avatar
most likely. but since i don't have your car sitting here in front of me there's no way to be certain. and yea theres a writeup for cleaning the iacv.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old Jan 7, 2009 | 01:46 PM
acmoc's Avatar
I started my car this morning and it started to run fine after 5 minutes or so
Old Jan 7, 2009 | 05:20 PM
acmoc's Avatar
It works fine soometimes, ten doesnt, once it warms it does it.
I'm cleaniing the iacv with car cleaner tomorrow
Old Jan 8, 2009 | 06:14 PM
acmoc's Avatar
Thanks guys, cleaned the iacv and it's better than before
GSRicer
Jul 5, 2009 08:34 PM
slo_ej8
May 21, 2008 08:44 PM
ic0n
Aug 2, 2003 07:36 PM
Ri5e
Aug 14, 2002 03:02 PM
mick
Jun 7, 2002 07:40 AM
